What's Your Fix for Floppy A/C Vents?? #1200304
03/20/12 03:51 PM
03/20/12 03:51 PM
Georgia
skh Offline OP
skh  Offline OP
Georgia
The left-right adjustment to my Charger's two center and one passenger A/C vents are extremely loose. They snap closed whenever the A/C fan speed is increased to medium or high.
What's a good fix for them?
Re: What's Your Fix for Floppy A/C Vents?? [Re: skh] #1200305
03/20/12 04:10 PM
03/20/12 04:10 PM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
how about gumming them with some rubber cement? You could probably apply it with a toothpick or something right where the vent blade pivots in the frame, just enough to firm them up a bit.
Just a guess FWIW, never had to do this myself. good luck!
Re: What's Your Fix for Floppy A/C Vents?? [Re: ErikR] #1200306
03/20/12 06:46 PM
03/20/12 06:46 PM
BDW Offline
BDW  Offline
Same problem here, and since I bypassed the Hi/Low switch to only supply voltage to the fan motor with a relay, the airflow really moves the vent.
