68 Dart Headlight switch removal - What gives ? #1200261
03/20/12 03:26 PM
03/20/12 03:26 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
So I'm removing my dash pads, radio, etc, etc, so I can repaint the dash in the dart.
I cant seem to get the knob off the headlight switch.
Am I missing something ? The knob should just pull off right ? I know to remove the switch you unscrew the chrome bezel at the base, but the knob has to come off first.
There is no setscrew in the knob that I can see, and I've pulled on it as hard as I dare and it wont come off. I'm worried about damageing the switch if I pull any harder.
Any ideas ?
Re: 68 Dart Headlight switch removal - What gives ? [Re: MileHighDart] #1200262
03/20/12 03:35 PM
03/20/12 03:35 PM
okla.
sam64 Offline
sam64  Offline
okla.
somewhere towards the back of the switch there is a small button,you have to push it down while pulling on the knob.
Re: 68 Dart Headlight switch removal - What gives ? [Re: sam64] #1200263
03/20/12 03:36 PM
03/20/12 03:36 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
It is a small metal button on the side.
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 Dart Headlight switch removal - What gives ? [Re: Rhinodart] #1200264
03/20/12 03:41 PM
03/20/12 03:41 PM
Lyons, CO
Lyons, CO
I'll give a look and see if I can find it, Thanks
Re: 68 Dart Headlight switch removal - What gives ? [Re: Rhinodart] #1200265
03/20/12 03:59 PM
03/20/12 03:59 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Small spring loaded button located lined up with the shaft of the knob, located on the switch side of the dash.Pull headlight switch on fully, depress the little button, push in slightly to release pressure, and knob and shaft will pull out.
Replacement? Shove the knob/shaft in.
When you get the knob/shaft assy out you will see the groove in the end that holds it in place.
Re: 68 Dart Headlight switch removal - What gives ? [Re: MileHighDart] #1200266
03/20/12 04:14 PM
03/20/12 04:14 PM
Lyons, CO
Lyons, CO
Got it, thanks again. I never would have thought to look on on the side of the switch for a majic button. But that did it.
