904 Adjustment
#1200090
03/20/12 08:28 AM
03/20/12 08:28 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
After installing a 360 where a 318 once resided the 904 now shifts way too early and sometimes even seems lost as to where it is. The 360 is more than twice the HP and torque of the old 318. Is there anyting I can adjust to imrpove the shift pattern? If so how?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 904 Adjustment
[Re: JohnRR]
#1200092
03/20/12 09:40 AM
03/20/12 09:40 AM
dfsmopars
Kentucky
What intake , what did you do about the 2bbl Throttle linkage , did you reuse it as is?
The last stupid question , what modifications did you do to the transmission ?
This is a 5.9 Magnum so the intake is an AirGap. I did reuse the 2V carb adapter but I modified the kickdown rod linkage so it would reach the carb in a similar fashion as before. There were no mods made to the transmission because my plan is to swap it out for an OD unit later this year.
Re: 904 Adjustment
[Re: dfsmopars]
#1200093
03/20/12 12:19 PM
03/20/12 12:19 PM
RapidRobert
lengthen the kickdown rod assy a bit at a time & see if you like the result (so at idle the trans lever is further rearward)
Re: 904 Adjustment
[Re: dfsmopars]
#1200094
03/20/12 02:45 PM
03/20/12 02:45 PM
Posts: 25,756 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What type of carb? If aftermarket, does it have the correct Mopar throttle lever extension?
