Oil pick up tube. Teflon sealer? #1199870
03/19/12 09:47 PM
03/19/12 09:47 PM
California
moparbroz Offline OP
California
Do I need to seal the threads on my 3/8" oil pick up?
Hebrews 11:1
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199871
03/19/12 09:49 PM
03/19/12 09:49 PM
Yes NPT threads (which those are) require a sealant
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199872
03/19/12 09:49 PM
03/19/12 09:49 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Yes as long as you don't get any inside the tube. Tim
Re: Oil pick up tube. Teflon sealer? [Re: RapidRobert] #1199873
03/19/12 09:51 PM
03/19/12 09:51 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
NPT threads do not REQUIRE sealant, but it is good insurance in this instance. The taper acts as the seal if made correctly. Tim
Re: Oil pick up tube. Teflon sealer? [Re: RapidRobert] #1199874
03/19/12 10:07 PM
03/19/12 10:07 PM
California
California
Plumbers teflon tape?
Hebrews 11:1
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199875
03/19/12 11:25 PM
03/19/12 11:25 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
If you want to be extra cautious you can use some actual thread sealant.
http://www.permatex.com/products/Automot...ead_Sealant.htm
I personally never used anything and have no pressure issues. Once spun in the tube gets very tight because of the taper.
Re: Oil pick up tube. Teflon sealer? [Re: Exit1965] #1199876
03/20/12 01:54 AM
03/20/12 01:54 AM
California
California
Thanks very much! I always get great and friendly advice from moparts members!
Hebrews 11:1
Re: Oil pick up tube. Teflon sealer? [Re: Exit1965] #1199877
03/20/12 07:48 AM
03/20/12 07:48 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I ran without sealant and had NO pressure issues at all...in fact pressue was ont he high side. When I recently re-did the oil pan/pickup, I added some thread sealer (red stuff) to make sure the pickup didn't twist out any as my motor is a stroker and the clearance b/t pickup and rotating assbly is tight! This was done to prevent the pickup from loosening, not to seal it...
Re: Oil pick up tube. Teflon sealer? [Re: cjskotni] #1199878
03/20/12 09:23 AM
03/20/12 09:23 AM
crlush Offline
crlush  Offline
No sealer, never had a problem
Re: Oil pick up tube. Teflon sealer? [Re: crlush] #1199879
03/20/12 11:26 AM
03/20/12 11:26 AM
California
California
Excellent! Thank you!
Hebrews 11:1
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199880
03/20/12 11:42 AM
03/20/12 11:42 AM
IMGTX Offline
IMGTX  Offline
I always used sealer and never had a problem.
It's added insurance and what does it cost? .001 Cents?
If the pickup is going to suck air past the threads it is going to do it when the oil is cold and thick and when your less likely to notice a problem on the gauge.
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199881
03/20/12 11:53 AM
03/20/12 11:53 AM
that'll work fine tho my preference is plumbers white paste (pipe dope) as it's thicker & I think seals better. Have you made your mind up yet
Re: Oil pick up tube. Teflon sealer? [Re: RapidRobert] #1199882
03/20/12 12:06 PM
03/20/12 12:06 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
while sealer can be used, a NPT joint requires a thread lubricant ( teflon tape and such are thread lurbicants, not sealers) they enable you to accurately torque a NPT joint as the tapered threads sometimes stop short of sealing without proper lubrication.
Re: Oil pick up tube. Teflon sealer? [Re: DJVCuda] #1199883
03/20/12 12:22 PM
03/20/12 12:22 PM
learned something new today
Re: Oil pick up tube. Teflon sealer? [Re: crlush] #1199884
03/20/12 02:14 PM
03/20/12 02:14 PM
Me too, for over 40 yrs of screwing them in until tight, no problems ever Why risk getting the tape or sealer into to the pump
Re: Oil pick up tube. Teflon sealer? [Re: Cab_Burge] #1199885
03/20/12 06:15 PM
03/20/12 06:15 PM
California
California
I am going with no sealer. Thanks everyone!!
Hebrews 11:1
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199886
03/20/12 08:51 PM
03/20/12 08:51 PM
California
California
Hand tightened as far as it would go with out stressing the neck and there are approximately 3 threads still visable. Any cause for concern?
Hebrews 11:1
Re: Oil pick up tube. Teflon sealer? [Re: moparbroz] #1199887
03/21/12 02:09 AM
03/21/12 02:09 AM
You want to make sure it is tighten all the way you can get it, I use a crescent wrench on one of the straight pieces to tighten them, that or a pipe wrench Once you have it tight, install the oil pan and pull the drain plug so you can check the hieght of the pickup off of the bottom of the oil pan with a flashlight or a piece of 1/8 inch welding rod or a straighten out coat hangar, the Mopar factory services manuals call for the stock pick up to touch the bottom of the oil pan
