Easy PCV question #1199822
03/19/12 08:29 PM
03/19/12 08:29 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
I am sure this will be a no brainer for you guys. My 440 had 2 breathers on it until tonight. I have seen many threads saying the engine would be happier with a pcv.
On the driver's side I have a breather and on the passenger side I installed the pcv and ran the line to the carb.
I didn't start the car yet because I wasn't gonna take it out and wanted to ask what to expect. Will the idle or timing be different? I am thinking timing won't be affected at all, right? Or will it start right up and run same as usual?
Scott
1969 Super Bee, 383/4 speed
Re: Easy PCV question [Re: StukaJU87] #1199823
03/19/12 09:00 PM
03/19/12 09:00 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
All you are doing is vetalating the crank case. It should have no impact on the tune.
I have mechanical Aptitude.
I can screw up anything.
Re: Easy PCV question [Re: bboogieart] #1199824
03/19/12 09:33 PM
03/19/12 09:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The PCV valve is a metered vacuum leak.
It will affect your mixture, you will probably need to tweak the idle mixture screw a bit. It might affect idle speed a bit, but it should start up ok.
Don't be the exception.
Re: Easy PCV question [Re: bboogieart] #1199825
03/19/12 10:00 PM
03/19/12 10:00 PM
Northern NJ
Northern NJ
That's along the line I was thinking. That center vacuum inlet on the carb had been plugged and now it will be drawing from the pcv valve so it stands to reason that something is gonna change.
Scott
Re: Easy PCV question [Re: StukaJU87] #1199826
03/19/12 10:50 PM
03/19/12 10:50 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yep, just readjust!
Unless you went in and made changes, almost every carb is designed for a PCV to be under it, so they tend to be a bit richer if you don't.
The breather on the other side is now going to be filtering the air going in, so expect it to be dirtier on the outside now.
