How often do you change your engine oil...
#1199804
03/19/12 08:17 PM
03/19/12 08:17 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Re: How often do you change your engine oil...
[Re: domingo]
#1199805
03/19/12 08:21 PM
03/19/12 08:21 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
About 3 times a year, if no problems happen. One in beginning of season, once in the middle of the season, and one in the fall shortly before I but it away.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1199806
03/19/12 08:24 PM
03/19/12 08:24 PM
Triple Threat
Renton Washington
With my old 340 I would change it twice a season, or about every 125 passes. Once at the beginning and once about half way through. Mild Hydraulic cam I never had an issue. If you have a more agressive solid cam you should probably do it more than that, not worth the risk.
[Re: domingo]
#1199811
03/19/12 10:02 PM
03/19/12 10:02 PM
Posts: 12,292 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Always at the start of the season and then, when the oil starts to get dark. Which usually means about 3/4 way thru the season.
Master, again and still
[Re: Dabee]
#1199813
03/19/12 11:50 PM
03/19/12 11:50 PM
Posts: 148 Montgomery, PA
dodge340dart
Montgomery, PA
I change the oil every 40 runs in the 340. Often that is five times a year and I always store the engine (for the winter) with fresh oil in it. I use Castrol Synthetic 5W-30 oil in the engine.
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion
2012 BSD Friday Street Racer Driver of the Year
3-time Jr. Stock Eliminator
2-time Mean Street Eliminator
'69 340 Dart 1.500 60ft, 11.359et, 117.08mph
[Re: Challenger 1]
#1199816
03/20/12 11:03 AM
03/20/12 11:03 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
In the big tire car we change it about avery 25-30 passes, just depends on when that happens. Never change it during a race always after so the number vaaries. Always still looks new but oil is cheap, well relatively. In the small tire car we change it after every race. So that has been every 4-6 passes so far. Hopefully we can figure out a way to stretch that to 8 soon However keep in mind these are both kinda high powered all motor race engines. If it were a mild solid cam type deal I would be on a much less regimented shcedule.
