ez efi vs double pumper #1199494
03/19/12 01:48 PM
03/19/12 01:48 PM
United states wisconsin
bigblockbryan Offline OP
okay im thinking about buying a ez efi system for my 1965 fury i got a double pumper right now on the car .That i like but its not mine are these ez efi systems good which one should i get? i do get one the 440 is 10.1 comp speed pro forged pistons scat h beam rods 452 heads and 484 comp cam dual plane intake mp electronic igition. 323 open rear with a 833 4 speed. Im pulling the car outta storage friday cant wait!!
Re: ez efi vs double pumper [Re: bigblockbryan] #1199495
03/19/12 01:51 PM
03/19/12 01:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ones expensive and one isn't, One you can buy parts at any store, One you can't, one you can fix on the side of the road, one you can't, One might give you better fuel milage, Both will require tuning, however on doesn't need a computer to do so... take ur pick.
Coming soon!!!!
Re: ez efi vs double pumper [Re: Mr.Yuck] #1199496
03/19/12 02:14 PM
03/19/12 02:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Holley's need a computer to tune? This is news to me. The whole point of the ez-efi is that it doesn't need a laptop to tune so that can't be what you're referring to...
Seriously though, unless you daily drive the car, I think you'd have a real had time justifying the cost of going to efi.
Re: ez efi vs double pumper [Re: Mr.Yuck] #1199497
03/19/12 02:17 PM
03/19/12 02:17 PM
crlush Offline
crlush  Offline
one you can buy for a couple hundred bux the other will cost you more than two grand by the time your done.
Re: ez efi vs double pumper [Re: DaytonaTurbo] #1199498
03/19/12 02:24 PM
03/19/12 02:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm talking about the on-board unit, not a lap top.
Re: ez efi vs double pumper [Re: Mr.Yuck] #1199499
03/19/12 02:28 PM
03/19/12 02:28 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I have this system on my car and IMHO, nothing about it compares to a carb other then there are 4 holes in it. It is by far and away a much more efficient system then you standard carb. Not that I do not appreciate a carb set-up, the points about being able to fix a more mechanical set-up are valid. The long and short of benefits for me are the following: Easily adjusted for any driving situation, self learning, adjusts itself for any elevation, and the most important...adjusts itself for different air temperatures which allows for better overall feel and easy hot starts. The throttle response will be instantly better.
The drawback is simply cost. You need to be fully committed going in as it requires a totally different fuel delivery system that creates more heat at higher pressure.
I upgraded to teflon lined fuel lines, and a Weldon 600A pump.
Here is an example of how the system can make your life EZer: Competing at the OUSCI, going down the backstretch on the roadcourse I noticed the car falling on its nose fairly dramtically at about 120mph. Reached down and adjusted the WOT AFR from 12.8 to 12.2 and the next lap around plenty of power down the straight. It took me 5 seconds to adjust.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: ez efi vs double pumper [Re: crlush] #1199500
03/19/12 02:30 PM
03/19/12 02:30 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Let the haters hate - hell most dont even know what they are talking about when they start pointing fingers at why they dont like EFI - but FWIW the EZ system uses all GM sensors - I had one go bad at Carlisle last year ( still ran ) and both parts houses had them in stock.
starting from scratch they cost about the same. if you factor tuning kits and fuel systems.
My recommendation?
Get a rock valley fuel tank ( with the fuel pump they put in a brand new tank ( I've never had a problem in the 2 years running it )
and get FAST part : 30226 base kit and do the fuel system yourself.
I've gained 20 hp on the dyno ( went from 2 holley 390's to over 2000 cfm ) and it runs better, starts cleaner and I DONT need a laptop to tune it.
When something goes bad it flashes and goes into limp mode, but will still get you home - I've packed tons of tools., and it has never left me stranded or needing anything other then a screwdriver for the one bad sensor ( I drove it for days in the rain with the throttle bodies in the elements, so It's understandable.
Re: ez efi vs double pumper [Re: DJVCuda] #1199501
03/19/12 05:50 PM
03/19/12 05:50 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Lots of EZ info on my web site including a list of how it differs from the XFI.
www.fastmanefi.com
I can answer any specific questions, but I can say that most problem installations in Mopars are improper fuel system setup, and intermittent switched 12V (by this I mean the power dropping out as the key goes from run to start and back), or noisy tach signal (the EZ needs a clean tach signal like from an MSD 6AL).
Re: ez efi vs double pumper [Re: bigblockbryan] #1199502
03/19/12 08:14 PM
03/19/12 08:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Years ago, I was fooling with Holley's Projection system, the old analog Alpha N setup.
Junk, even with the optional O2 setup. However, it did teach me a valuable lesson. Your fuel system is key, especially the pickup portion of it. On the days the system ran well, I could easily kill the engine with a hard turn or stop with less than half a tank. Some one mentioned Rock Valley, good choice but pricey so factor in that cost for your budget.
Don't be the exception.
Re: ez efi vs double pumper [Re: Supercuda] #1199503
03/19/12 09:31 PM
03/19/12 09:31 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Efi isn't something you do because its cheap...You also don't do it, because you wanted simple and no wires showing.
The EZ-efi is about as simple as it gets, but the fuel system needed to support efi will take a little thinking or guidance to get it right the first time.
I like my EZ efi, and I can say I hit a few bugs or issues along the way. Most are attributed to +30yr old Chrysler wiring that was never meant to work with more than an amp or two thru it...And one fricken PITA intermittent coil failure I could not locate...But finally found.
It is very responsive almost instantly. It is very, very tuneable on the fly with no tools, or laptop. And it will keep the tune right on the edge regardless of outside temp, humidity, or altitude...No carb will do that...Mine also netted almost the same ET back to back...It will as noted run with a bunch of sensors not hooked up or functioning...Really great in that respect.
A good running carb is great, EFI is awesome.....
Re: ez efi vs double pumper [Re: Dragula] #1199504
03/19/12 10:24 PM
03/19/12 10:24 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
i am no fuel system expert by any means but have you looked into msd's atomic efi? from what i have seen it looks relatively easy to install.
Re: ez efi vs double pumper [Re: 72d100] #1199505
03/20/12 12:08 AM
03/20/12 12:08 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
EZ has a return style system, keeps the fuel moving. MSD is a dead head system. Both systems are relative in nature other than that. MSD has the brain built into the throttle body. EZ is separate.
Re: ez efi vs double pumper [Re: Supercuda] #1199506
03/20/12 01:38 AM
03/20/12 01:38 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I also ran a Holley Projection. Non standard parts and a rotten analog ecu killed it for me. However, part throttle response absolutely blew the carb out of the water. I always thought that TBI with a good ECU would work fine for most of our cars. We will see I guess.
Re: ez efi vs double pumper [Re: Pool Fixer] #1199507
03/20/12 01:45 AM
03/20/12 01:45 AM
Manitoba, Canada
Manitoba, Canada
I have heard of some guys running that ecu with one of the generic aftermarket efi controllers and having good success.
Re: ez efi vs double pumper [Re: Viol8r] #1199508
03/21/12 12:14 PM
03/21/12 12:14 PM
Dragula Offline
Dragula  Offline
Actually on my EZ-efi I run a combination of both....
I have a return off the regulator, but the feed line up the the TB is a dead head unit on my set-up. It works really well. My regulator is mounted down on the frame rail and I run a supply line up and split it off to both TB rails as a dead head system. I figured at my HP level it really wouldn't matter. If I ran two TB's I would plum it a little differently though.
