Will I damage anything??? #1199477
03/19/12 12:24 PM
03/19/12 12:24 PM
California
moparbroz Offline OP
California
I want to re-install my rear-end so I can roll my car around. I have everything but the center section (Have 489 case, no guts). Will I damage my axles with out the chunk if I roll her around?
Hebrews 11:1
Re: Will I damage anything??? [Re: moparbroz] #1199478
03/19/12 12:31 PM
03/19/12 12:31 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I don’t think I would do it. What’s going to support and keep the inside end of the axle centered?
Re: Will I damage anything??? [Re: moparbroz] #1199479
03/19/12 12:38 PM
03/19/12 12:38 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
You could put a lenth of 2" steel tubing inside the rear housing where you can slide the axles in to support them. I think you'll be alright with that, but you could also use some wood wedges to secure/center the tubing into the empty bearingcaps.
Re: Will I damage anything??? [Re: Dabee] #1199480
03/19/12 12:38 PM
03/19/12 12:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
get a section of plastic pvc pipe and slide it over the axles in the center. and as long as your not running down the road at 30 mph it'll be fine
plan on replacing the bearings regardless
Re: Will I damage anything??? [Re: gtx6970] #1199481
03/19/12 12:44 PM
03/19/12 12:44 PM
As a general rule or from the axles supported w PCV pipe & being moved around
Re: Will I damage anything??? [Re: gtx6970] #1199482
03/19/12 12:47 PM
03/19/12 12:47 PM
California
California
Awsome idea's. Just rolling her around to my driveway and back into the garage. .001 MPH. Thanks guys!!
Hebrews 11:1
Re: Will I damage anything??? [Re: RapidRobert] #1199483
03/19/12 01:20 PM
03/19/12 01:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I would just as a general rule if moving it around with no lube and/or support on the bearings themselves
my idea is just to keep the axles from flopping around and should not be used to move the car any farther or faster than you can by hand
Re: Will I damage anything??? [Re: gtx6970] #1199484
03/19/12 01:27 PM
03/19/12 01:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Something to consider, the pipe idea is ok if your running Green bearings but the OE tapered bearings need a spacer in the middle to force the axle out so the bearing cone seats in the race... At the very least you'll destroy the seals running it with just a pipe...
Re: Will I damage anything??? [Re: 1_WILD_RT] #1199485
03/19/12 02:50 PM
03/19/12 02:50 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There will be some weirdness if still using stock adjustables.
Re: Will I damage anything??? [Re: 1_WILD_RT] #1199486
03/20/12 02:17 AM
03/20/12 02:17 AM
California
California
10-4. I have a set of green bearings just purchased from Dr. Diff and have not yet had them pressed on. Thanks much!!
Hebrews 11:1
Re: Will I damage anything??? [Re: 1_WILD_RT] #1199487
03/20/12 11:32 AM
03/20/12 11:32 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
This is incorrect. the weight of the vehicle forces the axles out. Its a glorified front wheel bearing setup.
The pipe deal is fine.
Re: Will I damage anything??? [Re: RemCharger] #1199488
03/20/12 12:34 PM
03/20/12 12:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You might want to take another look at the design of Mopar axle bearings before posting that comment...
Re: Will I damage anything??? [Re: 1_WILD_RT] #1199489
03/20/12 09:55 PM
03/20/12 09:55 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I stand corrected my apologies. But with the pipe in there I can't see it damaging anything, the bearing can only go in so far....?
As far as mopar bearings, I was thinking about the grand cherokees.
Re: Will I damage anything??? [Re: RemCharger] #1199490
03/21/12 12:51 AM
03/21/12 12:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Without some sort of solid spacer to push the axles out the taper of the bearing tends to push the axle in.. The first the that tries to stop the inward movement is the outer axle seal meeting the larger step on the axle so that grease seal gets destroyed.. It can't be serviced without removing the bearing so now the bearing is toast... Next thing to try stopping the axle moving inward will be the axle flange meeting the axle retainer... If your pushing the car the axle flange will grind away at the retainer.... Honestly probably wouldn't do allot of damage but why chance it....
