65-67 Satellite - Source for correct fitting MC?
#1199239
03/18/12 10:22 PM
03/18/12 10:22 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Hey, thanks for looking - Do you know of a source or part number can I turn to for a correctly-fitting MC for my all drum manual brake Satellite? It happens to be a '65 I'm converting to a dual circuit. Ideally I'd like a match to replace the MC in the photos below - cast part #2660809 - I think it's a Bendix. A Google search didn't give me clear results. Or, are there reliable rebuild kits that will let me reuse this one? I see YearOne has a kit but I trust NO supplier unless you guys vouch for it. BACKGROUND: I know parts store MC's are iffy, so I bought three new reman MC's to see if one would fit. None of them would install because the bolt holes were too large to accept the press-fit studs and the cup in the MC's plunger is so large that the pushrod won't "snap in" and stay in place. @#^%@$@!! All three MC's were the same crap: - AutoZone parts #10-1323P and 13-1323M (I know the P was for power brakes, but we were willing to try anything). - NAPA #P1874. ![](http://i224.photobucket.com/albums/dd133/nervitbreath/65%20Satellite/IMG_1937.jpg) ![](http://i224.photobucket.com/albums/dd133/nervitbreath/65%20Satellite/IMG_1936.jpg) Thanks, -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 65-67 Satellite - Source for correct fitting MC?
[Re: 67SATisfaction]
#1199240
03/18/12 10:37 PM
03/18/12 10:37 PM
67SATisfaction
Albany, NY
I'm sorry - one more question:
Is it normal for an MC (without the cover on) to shoot a jet of brake fluid straight up out of the front reservoir (R circuit) when you press the brake pedal down?
#1199244
03/19/12 12:43 AM
03/19/12 12:43 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Art,...the only rebuild kit I see for that master, available from Autozone, NAPA, etc that carries Duralast products is this pn# 22802 $29
[Re: DAYCLONA]
#1199246
03/19/12 10:01 PM
03/19/12 10:01 PM
67SATisfaction
Albany, NY
Thanks Andrew, SuperGas and Mike, At least you all confirm that they're out there and I can solve this if I keep trying hard enough. I found an old issue of MAction with a conversion from 1 to 2 circuit MC's. In the article, R.Ehrenberg lists a few other MC's that should fit.
Thanks for all the info Mike, super helpful!
That NAPA part in the image above is exactly what I bought from NAPA years ago. That same parts #1874 is still in use, but is now "too generic" and has the wrong bolt hole size and plunger size for my needs. I'll contact B54406barrel see what he says. Thanks again guys!
