head gasket question.. #1198923
03/18/12 03:20 PM
03/18/12 03:20 PM
New York
GTXed Offline OP
GTXed  Offline OP
New York
Finally getting around to getting this 440 back together and I have a question regarding installing the head gaskets. The deck of the 440 had the usual surface rust from sitting for a couple of years,nothing major and after hours of elbow grease I have them cleaned up. I dont ever recall using a gasket sealer when replacing head gaskets in years past ( its been a few years)but looking through the Chrysler manual they state to use a proper gasket sealer when installing head gaskets. Seeing that there may be slight pitting on the deck surfaces,should I use a sealer? If so,what would anyone recommend? Thanks ahead of time guys!
Re: head gasket question.. [Re: GTXed] #1198924
03/18/12 03:25 PM
03/18/12 03:25 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it depends on the type of gasket being used. if it's a composition type gasket it should be installed clean and dry they're probably referring to a steel shim gasket.
Re: head gasket question.. [Re: GTXed] #1198925
03/18/12 03:26 PM
03/18/12 03:26 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
No sealer required on a compositon style gasket. If you are using a steel shim, shoot them with some copper coat or some MOPAR gasket sealer.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: head gasket question.. [Re: GTXed] #1198926
03/18/12 03:27 PM
03/18/12 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On steel shim gaskets I always use K&W Copper Coat spray sealer.
Re: head gasket question.. [Re: John_Kunkel] #1198927
03/18/12 03:31 PM
03/18/12 03:31 PM
New York
GTXed Offline OP
GTXed  Offline OP
New York
Thanks guys... they are stock Fel Pro gaskets on a stock 69 440.. there wasnt any sealer on the originals when they came off,but I would rather be safe than sorry!
Re: head gasket question.. [Re: GTXed] #1198928
03/19/12 12:34 AM
03/19/12 12:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are they steel shim or composite , STOCK gaskets were steel shim and they did not say felpro just a mopar part number .
