Re: Installing Engine While Trans is Still in Car?
[Re: bordin34]
#1198897
03/18/12 02:49 PM
03/18/12 02:49 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
get the engine to mate with the trans..the converter will line up then..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1198898
03/18/12 02:57 PM
03/18/12 02:57 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
make sure torque conv is all the way in,inside the trans.just line up the 2 dowl pins and mate the trans and engine, then the torque conv. The torque convertor will only bolt up 1 way.so if it's off the first time-rotate conv to another hole and try it.1 in 4 chance.The torque convertor will sit farther in the trans than needed.When engine-trans are bolted together the conv will come towards the engine some.maybe 1/4 inch?.If engine hits torque conv before engine-trans seat,then the conv is not in all the way.Don't forget to lock tight the torque convertor bolts.Usually need to jack the trans up to help line up- then get the mounts adjusted.Sometimes leaving the motor mount brackets a little loose at the engine will give you some more wiggle room.if you're doing headers,those will need to be in place with the engine going in.Most (not all) will not go in very easy will engine trans in place.
[Re: bordin34]
#1198900
03/18/12 04:29 PM
03/18/12 04:29 PM
70AARcuda
las vegas
gotta play with the angles of the back of the motor and trans....use a floor jack under the trans to change its pitch..
sometimes it is a PIA with spool mounts.
Tony
[Re: 70AARcuda]
#1198901
03/18/12 05:11 PM
03/18/12 05:11 PM
RapidRobert
might see if you can loosen the trans mount so you can move the trans back a bit
[Re: bordin34]
#1198903
03/18/12 06:04 PM
03/18/12 06:04 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I think the converter is all the way back but the snout of the converter seems to hit the flex plate
Using one hand placed in the middle of the converter spin it as you force it rearward into the bell housing, sounds like you don't have it fully seated rearward for engine installation/alignment to the transmission
