275/50r 15 on a 71 A-body? #1198428
03/17/12 03:51 PM
03/17/12 03:51 PM
southern illinois
Y
yellowscamp Offline OP
Y
southern illinois
Has anyone out there ever run this tire on a 71 scamp or dart with the springs moved in line with the frame rails? The springs wont even be a factor. I have the complete width of the factory wheel tubs to work with. They are 12 inches wide. I think I will have about 1/2 inch of clearence on each side if it is centered correctly. Will that be enough clearence? Any picks would be appreciated.
Re: 275/50r 15 on a 71 A-body? [Re: yellowscamp] #1198429
03/18/12 04:40 AM
03/18/12 04:40 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
You should be perfectly fine. Lot's of guys with 17-18" wheels run the same overall tire dimensions. FWIW I have a friend with 245/60/15's on his 71 Demon. It just has SS springs and adjustable shocks. He only get's a little rubbing when going over huge bumps.
Re: 275/50r 15 on a 71 A-body? [Re: MuuMuu101] #1198430
03/18/12 09:11 AM
03/18/12 09:11 AM
southern illinois
Y
Y
southern illinois
Thanks for the input. Anybody else?
Re: 275/50r 15 on a 71 A-body? [Re: yellowscamp] #1198431
03/18/12 09:34 AM
03/18/12 09:34 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
not really what your asking for but on my 71 dart i have 295/50/15 springs moved in but its also mini tubbed.
Re: 275/50r 15 on a 71 A-body? [Re: 65rbdodge] #1198432
03/18/12 11:52 AM
03/18/12 11:52 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The key would be getting the correct offset on the rim. It should fit, but you could have a rub problem with the car loaded going over bumps. You might want to ask this question over on For A Bodies Only. The A's get more love over there
Re: 275/50r 15 on a 71 A-body? [Re: yellowscamp] #1198433
03/19/12 10:20 AM
03/19/12 10:20 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Can you even get 275/50x15 tires on an ongoing basis to make this set up viable in the long run?
Re: 275/50r 15 on a 71 A-body? [Re: TC@HP2] #1198434
03/19/12 08:36 PM
03/19/12 08:36 PM
southern illinois
Y
Y
southern illinois
Dont know. Good food for thought though. Maybe a 275/60r15 would be better if it will fit.
