Re: B-body rear end question
[Re: jake4cars]
#1198400
03/17/12 05:33 PM
03/17/12 05:33 PM
Posts: 905 SD
zrxkawboy
SD
Not sure about '69, but my '67 Belvedere, slant-6/3-spd has a 7-1/4.
It's Swifty! Swifty, you toad sucker!
[Re: Cab_Burge]
#1198404
03/19/12 05:28 PM
03/19/12 05:28 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'69 was the first year for the 8 1/4" but they were mostly used behind small V8's (318, 383-2). The 7 1/4" is more likely to be found in a /6 car.
[Re: jake4cars]
#1198405
03/19/12 06:02 PM
03/19/12 06:02 PM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
What's left of the one in my side yard has a 7-1/4" under it.
Everybody makes fun of a hillbilly until they need something fixed
[Re: Kern Dog]
#1198406
03/19/12 06:05 PM
03/19/12 06:05 PM
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
If it is an 8 3/4" and is original, it may have the small 1 3/8" pinion '741 case. TRY to get gears or a SG for THAT oddball!
Sure grip is interchangable for all 8-3/4s. Bearings for the SG are different between cone and clutch type but it's the ID that's different, they're the same as far as the case goes. I took one from a 741 and put it in a different case. Still have the case and gears from the 741, should probably scrap it.
