rod bearing confusion #1198366
03/17/12 01:22 PM
03/17/12 01:22 PM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
maybe I'm missing something but all the rod bearings I'm looking at for b/rb engines don't have the oil hole/groove to match the groove on parting line of the rod/cap. Isn't that supposed to spray oil on the opposit cylinder wall ?
Re: rod bearing confusion [Re: DOUGG] #1198367
03/17/12 01:28 PM
03/17/12 01:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It has been found unnecessary & eliminated....
Re: rod bearing confusion [Re: 1_WILD_RT] #1198368
03/17/12 11:51 PM
03/17/12 11:51 PM
Exactly
Re: rod bearing confusion [Re: DOUGG] #1198369
03/18/12 12:05 AM
03/18/12 12:05 AM
No, it is not suppose to spray on the opposite cylinder wall. It is there to oil the camshaft You can file or cut the groove in the bottom shell if you want, others have done that
Re: rod bearing confusion [Re: Cab_Burge] #1198370
03/18/12 12:07 AM
03/18/12 12:07 AM
In that case I'd sure want to add em
Re: rod bearing confusion [Re: RapidRobert] #1198371
03/18/12 09:55 AM
03/18/12 09:55 AM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
more comfusion. the mopar perf. engine book says that if the rods are oriented correctly the groove will put oil on the opposit cyl. wall, but, if one of it's purposes is to help lube the cam, could be a reason why we have so many cam failures ? most of us tend to "push" our engines & maybe other sources for cam lubing can't keep up
Re: rod bearing confusion [Re: DOUGG] #1198372
03/18/12 10:06 AM
03/18/12 10:06 AM
dogdays Offline
dogdays  Offline
These grooves have been there since the beginning of the automotive age, it seems, and they have always been there to oil the cylinder walls. It is wishful thinking to think that they are for oiling the camshaft. They don't aim at it, either. Most camshaft oiling has been by splash, with oil getting past the lifters and some from the valley supplementing.
When you're building an emissions controlled engine you want to keep as much oil out of the combustion chamber as you can. It seems that there is enough oil mist in the crankcase to oil the cylinder walls without those extra squirts from the rods. The use of lower-tension rings to reduce friction also makes extra oil on the cylinder walls bothersome.
This explains the general trend away from these grooves.
For the high performance engine, extra oil in the combustion chamber can cause knock, as oil has a much lower octane rating than gasoline.
R.
Re: rod bearing confusion [Re: dogdays] #1198373
03/18/12 10:21 AM
03/18/12 10:21 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
R.
Re: rod bearing confusion [Re: dogdays] #1198374
03/18/12 07:24 PM
03/18/12 07:24 PM
R.
Lets see, inline four and six cylinders don't have them,V6, V8,V12 and non OHV V12 have them Another thing to consider is that the standard V8 rod bearings do not have oil pressure for 360 degrees of crankshaft travel with single groove main bearings, so the oil pressure is not there to squirt oil into the cylinders at all times Most commercial turbocharged motors, diesel and gasoline, have piston oilers installed in those motors to squirt oil into the bottom of the piston domes to cool them
