Valve stem seals in oil pump pick up? #1198157
03/16/12 11:09 PM
03/16/12 11:09 PM
SC
V194 Offline OP
V194  Offline OP
SC
Decided to remove the oil pan from an engine that is in the garage sitting for over 20 years. Its a used engine and I found the oil pump p/u is filled with fragments of the valve stem seals.
How common is this?
Re: Valve stem seals in oil pump pick up? [Re: V194] #1198158
03/16/12 11:12 PM
03/16/12 11:12 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i see it on the old engines all the time---they just die from old age---good thing you looked and removed them from the pan and the pump strainer----bob
Re: Valve stem seals in oil pump pick up? [Re: savoy64] #1198159
03/16/12 11:16 PM
03/16/12 11:16 PM
SC
V194 Offline OP
V194  Offline OP
SC
Yes the fragements are hard as rocks.
So pretty common huh?
Re: Valve stem seals in oil pump pick up? [Re: V194] #1198160
03/16/12 11:23 PM
03/16/12 11:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Very common.
Re: Valve stem seals in oil pump pick up? [Re: V194] #1198161
03/16/12 11:46 PM
03/16/12 11:46 PM
How common is this?
Which type and year engne are you working on? The first oil pump failure I had in a Mopar was in a 1957 Chrysler 300C, a piece got through the strainer locking up the oil pump shearing the oil pump shaft That was 500 miles from home If it is a small block you may want to look up inside the pickup and see if there is a hole in the center of the screen like all the early Mopar V8 motors had
Re: Valve stem seals in oil pump pick up? [Re: Cab_Burge] #1198162
03/16/12 11:48 PM
03/16/12 11:48 PM
SC
V194 Offline OP
V194  Offline OP
SC
1971 340
Re: Valve stem seals in oil pump pick up? [Re: V194] #1198163
03/17/12 01:01 AM
03/17/12 01:01 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Completely normal for a 40 yr old engine, heck I see it in 10 yr old engines. Rubber valve seals just dont last forever.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
