Is this a good flow rate? #1198110
03/16/12 09:33 PM
03/16/12 09:33 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
my heads are ported and polished and are suppose to flow 250cfm at .500 lift on a 440,cast heads
Re: Is this a good flow rate? [Re: CUDA8U] #1198111
03/16/12 10:11 PM
03/16/12 10:11 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You don't say anything else about the heads so all I can say is for a Slant 6 that would be pretty good and for a 426 Hemi that would totally suck.
Re: Is this a good flow rate? [Re: CUDA8U] #1198112
03/16/12 11:50 PM
03/16/12 11:50 PM
That is very comparable to other 440 Mopar BB iron heads that had similar work that where flowed on a Super Flow 600 bench at 28 inches of water
