Re: Welding on axle housings damage anything?
[Re: NicksGarage]
#1198088
03/16/12 09:56 PM
03/16/12 09:56 PM
moparpollack
Lil Herman
Lil Herman
85086
If you look they are welded together from the factory. So welding on them won't be a problem.
[Re: NicksGarage]
#1198090
03/16/12 10:58 PM
03/16/12 10:58 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I welded new caliper mounting brackets to an axle before. no problems at all.
Don't know if it was right or wrong, but I put a wet rag around the tube on the "back side" of where I was welding, to help keep things cool. I placed the rag on, THEN started to weld, so the metal never got "shocked" it did get hot and was hissing the water out of the rag, but I THINK it helped keep heat down on the axle tube itself.
Right or wrong, I put 4,000 miles on that axle with my big block Dakota without any problems, and my buddy is running it in his 318, T-56 Dakota that's his daily driver and has probably 10K miles on it since we put the axle in it last spring.
**Photobucket sucks**
[Re: 70Cuda383]
#1198091
03/16/12 10:59 PM
03/16/12 10:59 PM
70Cuda383
Marysville, O-H-I-O
Oh, and I welded on it with the axles OUT of the tube....however, if I had it to do over again, I'd probably slide the axles in, just to help give something strong that might help prevent any distortion
[Re: moparpollack]
#1198092
03/17/12 12:02 AM
03/17/12 12:02 AM
Posts: 4,127 Ramona, CA
NicksGarage
Ramona, CA
I know that, but that is in a factory and the housings probably aren't welded with the axles, bearings and seals in there. Who knows what they did here, the welds were kind of sloppy too.
[Re: 70Cuda383]
#1198095
03/18/12 04:41 PM
03/18/12 04:41 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Don't think for a minute that a pair of axles is doing anything for rigidity during welding.
[Re: BigBlockMopar]
#1198096
03/18/12 06:11 PM
03/18/12 06:11 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Welding thicker pieces is just like welding sheet metal. A little at a time and you'll be fine. Remember, anything that is welded gets smaller once it cools.
[Re: NicksGarage]
#1198097
03/18/12 07:35 PM
03/18/12 07:35 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
I'm not trying to put big wheels on the car, it's just a cruiser. I have 15" chrome road wheels on it now and they fit fine. From the axle comparison chart in the tech archives it shows the '67 axle being slightly narrower drum to drum than the '64 but that shouldn't cause me any issues.
I doubt I'll go get the thing this weekend as it's supposed to rain and that yard gets pretty mucked up. I actually first saw it a couple weeks ago when it was half-price day but it was close to closing time. It's only $88 regular price anyway but I need to drag a friend down there to help me with it so I don't throw my back out again.
I love your wagon
[Re: 70Cuda383]
#1198098
03/18/12 08:54 PM
03/18/12 08:54 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Actually you would have been better off letting the heat dissipate into the rest of the axle housing. Isolating it with wet rags caused more heat build up in the end of the axle. Probably still no big deal in this case but it could be a factor when welding on something longer or if it were out in the middle of the axle shaft.
[Re: Scott Carl]
#1198099
03/18/12 09:50 PM
03/18/12 09:50 PM
70Cuda383
Marysville, O-H-I-O
the mount pads were about 4" from the end of the tube, and the wet rag was on the outside of the plate, keeping the heat out of the end of the tube. I didn't put anything on the welded side of the flange because I didn't want water cracking/contaminating the welds as they cooled off.
[Re: BigBlockMopar]
#1198100
03/18/12 09:51 PM
03/18/12 09:51 PM
70Cuda383
Marysville, O-H-I-O
no, they definitely are not the same as a secure mounted welding jig, but surely having the axle shafts in the tubes anchored into the differential and held in place with the wheel bearings, would be stronger than just air in the axle tubes?
[Re: 70Cuda383]
#1198101
03/19/12 06:37 AM
03/19/12 06:37 AM
BigBlockMopar
The Netherlands
In worst case the axles will bend aswell. You cannot prevent warpage when welding by trying to force steel to stay in position. The only way to prevent warpage is to carefully apply the (welding)heat.
Even a welding jig is just there to keep parts aligned before welding. Any significant warpage that is present after welding can usually be corrected again by applying heat in the right locations. There are some clips on youtube on this subject.
