Re: I got the 904 running tonight
[Re: 70AARcuda]
#1198052
03/16/12 08:24 PM
03/16/12 08:24 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
check your linkage...
I will do that, but the headers are too hot right now. Just wondering if it could be anything else while I'm waiting.
[Re: 70AARcuda]
#1198053
03/16/12 08:54 PM
03/16/12 08:54 PM
JonC
Millinocket, Maine
I've been thinking, this is on a 72 Cuda. When I got to the point of putting the rod between the floor shifter and the arm on the tranny I wasn't sure if the part that had the adjustment on it went on the shifter part or the tranny arm. I have it on the shifter arm, any thoughts?
[Re: JonC]
#1198055
03/17/12 04:38 PM
03/17/12 04:38 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it won't move forward in Drive but will move in manual Low the overrunning clutch (sprag) has failed.
[Re: JonC]
#1198057
03/17/12 07:02 PM
03/17/12 07:02 PM
Posts: 612 Nampa, ID
None2Slow
Nampa, ID
Check your fluid level.
edit: missed that. filter may be dirty.
[Re: None2Slow]
#1198058
03/17/12 07:08 PM
03/17/12 07:08 PM
JonC
Millinocket, Maine
This is a new rebuild using low gear set, 4 planetary set from a donor tranny. New filter and fluid is ok. This is my first build.
[Re: JonC]
#1198060
03/17/12 07:35 PM
03/17/12 07:35 PM
John_Kunkel
Rio Linda, CA
If it's a fresh trans you might have assembled the sprag backwards i.e. the springs on the wrong side of the rollers.
