Odd Trans Issue #1197994
03/16/12 03:34 PM
03/16/12 03:34 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Having an odd issue with the 904 in my Duster. It is about a year on the last rebuild, with approximately 5000 miles since that time. The problem is with gear selection. When I go to start it in park, it will do so, but lunges forward a bit and acts as if it has a load on it when I rev it, much like it is stuck partially in a forward gear. When shifted to reverse, nothing occurs, maybe slight forward movement. Neutral will allow engine starting, but again, it lunges forward at bit when it lights and acts as if there is a load on it. Drive will move the car forward and it should shift ok. First and second gear should be ok. Why is this?
I tried adjusting all of the linkage down on the trans to no avail. Next, I disconnected the linkage and moved the shift lever on the trans by hand. Each gear selection clicks as it should, but when I go to start it, same thing...its acts like there is a load on it and there is no reverse even in reverse!
The fluid is clean and full and doesnt smell burnt.
I am at a loss. Could there be a governor inside thats clogged, or linkage falling apart just inside the trans? Something in the valvebody?
Interesting thing to note is that it did this last week after a 20 mile drive to work on the highway and when I went to put it into reverse to park, same issue. I let it cool off and crawled under the car to play with the linkage a bit. This was about two hours later and when I tried it again, it went back to normal for the rest of the day. This time, it is in the garage and everything is cold. Three hours of tinkering yesterday yielded nothing.
Any suggestions?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Odd Trans Issue [Re: MoparJ] #1197995
03/16/12 04:26 PM
03/16/12 04:26 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
904's are good for breaking reverse bands, you will have to drop the pan to see
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Odd Trans Issue [Re: MoparJ] #1197996
03/16/12 04:41 PM
03/16/12 04:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Lunging forward in Park/Neutral and a balky Reverse are signs of a rear clutch that's not fully releasing. Can't be fixed without removal/disassembly.
Re: Odd Trans Issue [Re: John_Kunkel] #1197997
03/16/12 06:54 PM
03/16/12 06:54 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
If that is the case, that is just grand. Not even 11 months since last rebuilt. Had a converter take out the last trans prior to that. Getting fed up with automatics
Re: Odd Trans Issue [Re: 440lebaron] #1197998
03/17/12 02:16 AM
03/17/12 02:16 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Never had to replace a 904 band from wear or breakage, opposed to dozens of 727's. Fast idle on startup used to be death on 727 low/reverse bands, to the point we'd park cars to not have to back up with a cold engine.
Even the valve bodies that suggest using a billet low/reverse servo, like an A&A LBA manual V/B, a 904 can still use a stock band.
To the O/P - like John said - you have an issue with the forward (rear) clutch not releasing.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Odd Trans Issue [Re: Evil Spirit] #1197999
03/19/12 01:23 PM
03/19/12 01:23 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Took out for another drive and it was the same. Did a couple of brake stands and low and behold, the trans starts acting normal again, reverse and all. Took it home, dropped the pan and flushed the fluid and changed filter. Still ok currently. My hunch is that when the converter grenaded a year agom the trans shop didnt completely flush and clean out the trans, allowing crap to stay in the valvebody. I cleaned it out as well. There was some shavings (probably from the old converter) and normal wear clutch dust. shifting perfectly now and nice and firm. Will keep an eye on it and probably flush the trans again soon.
