70 Charger Steering Column question/repairs #1197818
03/16/12 12:38 AM
03/16/12 12:38 AM
Texas
E
ef8Cuda340 Offline OP
E
Texas
My 70 Charger had a front end collision in its previous life. Mechanic told me it looks like the column has collapsed on the inside and that I should look for another one. This is for a 4 spd, power steering car.
Does anyone rebuild these? If so, for about how much? Whom shall I contact? Price for a used one?
Any help is appreciated!
thanks.
Re: 70 Charger Steering Column question/repairs [Re: ef8Cuda340] #1197819
03/16/12 01:03 AM
03/16/12 01:03 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Uhhhh.... could you FIND a rarer part to go bad? 1970 was the last of the 2nd generation Chargers and the first to use a column ignition. Add in the rarity of a 4 speed and your replacement options are pretty slim. A one year column.....Hmmm.
Scott Smith Harms restores many things, maybe he may know. He is a member here.
Re: 70 Charger Steering Column question/repairs [Re: Kern Dog] #1197820
03/16/12 01:09 AM
03/16/12 01:09 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The column is designed to collapse on the inside, it's a safety feature.. Chrysler use to sell a kit to repair the column.... Basically a rubber glue that would reattach the tube to the shaft.. They are double D parts so rotating motion is transferred but the length can change....
Fact is an ebay search shows....
http://www.ebay.com/itm/NOS-MOPAR-1970-7...tr#ht_500wt_922
Re: 70 Charger Steering Column question/repairs [Re: 1_WILD_RT] #1197821
03/16/12 01:15 AM
03/16/12 01:15 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
My god R/T !! Talk about a guy pulling a rabbit out of his hat! Very impressive!!!
Re: 70 Charger Steering Column question/repairs [Re: Kern Dog] #1197822
03/16/12 01:17 AM
03/16/12 01:17 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Just lucky... The fact I had a picture with a part number had no bearing...
Re: 70 Charger Steering Column question/repairs [Re: 1_WILD_RT] #1197823
03/16/12 09:44 AM
03/16/12 09:44 AM
Texas
E
E
Texas
That answers the repair question. Any others on who sells repaired ones or someone with a used one?
thanks!
Re: 70 Charger Steering Column question/repairs [Re: ef8Cuda340] #1197824
03/16/12 10:30 AM
03/16/12 10:30 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Contact Mike Mordarski for column restoration & repair. He does a great job at a reasonable price. michael.mordarski@gmail.com
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Charger Steering Column question/repairs [Re: 70gtx440dana] #1197825
03/16/12 10:33 AM
03/16/12 10:33 AM
Lansing, MI
Lansing, MI
Here is an Ebay unit: http://www.ebay.com/itm/Mopar-Steering-C...=item2ebbb2118b This is a pretty good price for a restored unit. Maybe the seller will take yours as a core deposit or restore yours?
Re: 70 Charger Steering Column question/repairs [Re: ef8Cuda340] #1197826
03/16/12 11:35 AM
03/16/12 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I just got my new unit from these guys. Great piece but they 'aint cheap http://stores.ebay.com/Norms-Speed-Shop?_rdc=1
I neede =d a manual floor shift unit. I have in the car now, complete w/ new harness a PS column shift unit, that will be coming out this weekend. If you are intrested PM me. You'd have to swap out the shifter collar to convert it. I'm only swapping it out because w/ my stage VI heads the header tube hit's the PS cupler.
Coming soon!!!!
Re: 70 Charger Steering Column question/repairs [Re: Mr.Yuck] #1197827
03/16/12 11:06 PM
03/16/12 11:06 PM
Western NY
19SuperBee70 Offline
Western NY
I just repaired mine. PO took an original manual shaft and compressed it to use on a power gearbox. I put the shaft back to the original length, drilled through the holes in the outer shaft and used nylon screws I but from Valu to keep the shaft in the correct position. the nylon screws perform the same function as the original plastic/nylon material the factory used, the nylon will break in an accident and allow the shaft to compress. the nylon bolts cost me 30 cents each. in the attached pic you can see both the inner and outer shaft. The white marks on the inner are plastic and line up with the holes on the outer shaft. I have more pics if you need any. Shaft is from a 70 superbee manual shift car so should be the same as yours.
