Challenger Drive shaft question 904 to 727 TF #1197674
03/15/12 07:22 PM
03/15/12 07:22 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
What do I have to do to my 71 challenger 318/904 driveshaft to make it work on my 340/727 swap. I have a 489 8 3/4 rear end now. The original rear was a 741 case. Thanks in advance again!
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Challenger Drive shaft question 904 to 727 TF [Re: fireeng] #1197675
03/15/12 07:37 PM
03/15/12 07:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the u-joints in the 727 slip yoke are the same as the u-joints in the driveshaft you will just have to shorten the driveshaft four inches. If the u-joints in the slip yoke and rear end yoke are different you'll also have to use conversion u-joints.
Re: Challenger Drive shaft question 904 to 727 TF [Re: John_Kunkel] #1197676
03/15/12 08:22 PM
03/15/12 08:22 PM
BDW Offline
BDW  Offline
Re: Challenger Drive shaft question 904 to 727 TF [Re: BDW] #1197677
03/15/12 10:06 PM
03/15/12 10:06 PM
Connecticut
biginchmotor Offline
Connecticut
I have a nice used one from a 73 Challenger that had a 340/727 trans, has the small u joints though. If you need a length: center of u joint cap to center of u joint cap is 45 3/4 inches. Weld to weld is 42 1/4 inches. Let me know, John.
