Hyd roller cam thrust button? billet timing cover? #1197476
03/15/12 01:58 PM
03/15/12 01:58 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
I need to install a thrust button and I suppose use a stronger timing cover. Question is, will a stock cover be adequate? if not what are my options for a cover? Ide rather not use a cast cover that requires me to space the water pump housing because it will complicate the pulley alignment. Is there a billet sheetmetal cover that would work?
Thank guys
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Hyd roller cam thrust button? billet timing cover? [Re: 540CUDA] #1197477
03/15/12 03:26 PM
03/15/12 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
weld in a steel spacer in the stock cover for the
proper spacing for the cam
Re: Hyd roller cam thrust button? billet timing cover? [Re: 540CUDA] #1197478
03/15/12 04:04 PM
03/15/12 04:04 PM
AndyF Offline
AndyF  Offline
My billet covers fit under a stock water pump. I also make a matching thrust button. The cover is AR224, the button is AR281. Hughes Engines has them in stock.
Re: Hyd roller cam thrust button? billet timing cover? [Re: 540CUDA] #1197479
03/15/12 04:20 PM
03/15/12 04:20 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I used a 440 Source alum timing cover and a cam button. The stock cover will work if you reinforce it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hyd roller cam thrust button? billet timing cover? [Re: HemiRick] #1197480
03/15/12 06:15 PM
03/15/12 06:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Both Muscle Motors and Promax sell a NICE cast cover that fits under the stock pump (take my word, I just installed it). I used a roller button but did the following to make it fit with .001" clearance:
1) remove the .030 washers
2) use an .047 timing cover gasket (aftermarket)
3) put a .010 shim behind the button (cut a piece of feeler gauge to fit)
Also, you will have to cut the lip off the oil slinger or it will gouge the cover. Without the thick gasket you may not be able to use the slinger at all.
I kept the clearance tight because I used a roller button. If you use a solid nylon button you might want to open that up a bit. Avaid aluminum buttons like the plague, they WILL gall and spit bits into your motor.
Now then, If you're interested I also have an unused 440Source cover for sale!
Re: Hyd roller cam thrust button? billet timing cover? [Re: 540CUDA] #1197481
03/15/12 06:27 PM
03/15/12 06:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
For those wanting to use a stock cover, here's the simple solution...
Install the timing cover with gasket. Mix up some epoxy or use construction adhesive and stick a good wad in a piece of saran wrap and fold the saran to contain the goo. Install the water pump with gaskets with the wad of goo between the pump and cover. Let it set till hard. Remove everything and install your cam button and timing cover with gaskets. Check the clearance and adjust by shimming behind the button with pieces of feeler gauge (do your best not to deflect the cover). Once you have the desired clearance, permanently attach the cover. Take the wrap off the solidified goo and with a THIN FILM of the same stuff secure it to either the cover or the water pump in roughly the same spot the cam button is. Permanently attach your water pump.
Re: Hyd roller cam thrust button? billet timing cover? [Re: Stanton] #1197482
03/15/12 11:48 PM
03/15/12 11:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A few shots of the cast cover. It's machined smooth on the inside where the button goes. The cover is also thick enough that I could drill and tap a hole so I could stick a dial indicator on the top sprocket and measure the endplay.
Re: Hyd roller cam thrust button? billet timing cover? [Re: Stanton] #1197483
03/15/12 11:49 PM
03/15/12 11:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
'nother one
Re: Hyd roller cam thrust button? billet timing cover? [Re: Stanton] #1197484
03/15/12 11:53 PM
03/15/12 11:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
last one
Re: Hyd roller cam thrust button? billet timing cover? [Re: Stanton] #1197485
03/16/12 12:51 AM
03/16/12 12:51 AM
AndyF Offline
AndyF  Offline
I include a set up plate with my billet timing covers. The setup plate has a slot in it for a dial indicator. Once the end play adjustment is set, then the setup plate is removed and the cover plate is installed.
Re: Hyd roller cam thrust button? billet timing cover? [Re: AndyF] #1197486
03/16/12 10:30 AM
03/16/12 10:30 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hey, you stole my idea
Re: Hyd roller cam thrust button? billet timing cover? [Re: Stanton] #1197487
03/16/12 02:35 PM
03/16/12 02:35 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
Thanks for all the help guys. I am losing my mind though. I forgot I did this on my other engine a long time ago and used the AR billet cover. Wow, time to eat some brain food.
Re: Hyd roller cam thrust button? billet timing cover? [Re: 540CUDA] #1197488
03/16/12 05:30 PM
03/16/12 05:30 PM
AndyF Offline
AndyF  Offline
I was kind of wondering about that!
