Clutch attaching bolts #1197309
03/15/12 12:21 AM
03/15/12 12:21 AM
70duster340 Offline OP
Do the bolts need to be a specialty type, such as ARP, or will any type do? Maybe grade 8 or something like that? This is for attaching the clutch to the flywheel.
TIA!
Re: Clutch attaching bolts [Re: 70duster340] #1197310
03/15/12 12:24 AM
03/15/12 12:24 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
I assume you mean pressure plate bolts.
A lot of parts stores carry Mr gasket 3/8" coarse for chevrolet, which work well.
The PP-specific bolts have a correct length shoulder under the head to center and locate the pressure plate, and the shoulder also pilots into the flywheel a little.Use these.Not hardware grade 8s.
Re: Clutch attaching bolts [Re: Sixgun] #1197311
03/15/12 12:30 AM
03/15/12 12:30 AM
My apologies. Yes, that is what I meant.
Thanks for the quick response!
