Drum vs Disc - rim backspace? #1197266
03/14/12 11:36 PM
03/14/12 11:36 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
14" factory steel rims, I replaced the 9" front drums on the Dart with a stock KH disc setup. Now the rims clamp down on the caliper. Is there a different back space for disc equipped cars??
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Drum vs Disc - rim backspace? [Re: busboy] #1197267
03/15/12 12:29 AM
03/15/12 12:29 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Its a different wheel. Tim
Re: Drum vs Disc - rim backspace? [Re: astjp2] #1197268
03/15/12 02:56 AM
03/15/12 02:56 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Did they have disc brakes on 14" wheeled cars? I would think they would be on 15" wheels. I don't think backspacing is going to do to much for you.
Re: Drum vs Disc - rim backspace? [Re: astjp2] #1197269
03/15/12 07:20 PM
03/15/12 07:20 PM
busboy Offline OP
busboy  Offline OP
Tim, any idea what backspace I'm looking at for a disc wheel?
Re: Drum vs Disc - rim backspace? [Re: busboy] #1197270
03/16/12 03:25 PM
03/16/12 03:25 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Like Tim said, disc brakes use an entirely different wheel. Drum brake wheels tend to be more flat on the backside. Disc brake wheels have a bulge in them to clear the calipers. Both can have the identical backspace. Backspace is not the issue. If you want to stick with 14" wheels, look for something off a Aspen/Volare in 14". Once you get them side by side to your drum wheels, you'll see the obvious difference.
Mnay poeple forget that back in the day, there was a difference in disc brake and drum brake wheels.
Re: Drum vs Disc - rim backspace? [Re: TC@HP2] #1197271
03/23/12 01:38 AM
03/23/12 01:38 AM
busboy Offline OP
busboy  Offline OP
Ok, thanks, I'm always learning something on this forum
Re: Drum vs Disc - rim backspace? [Re: TC@HP2] #1197272
03/23/12 02:04 AM
03/23/12 02:04 AM
busboy Offline OP
busboy  Offline OP
So would all SBP 14 x 5 1/2 rims be disc brake ones then? I thought that's what came on v8 powered, therefore disc equipped, a-bodys??
Re: Drum vs Disc - rim backspace? [Re: busboy] #1197273
03/23/12 04:05 AM
03/23/12 04:05 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Correct, the factory SBP 14X4.5" wheels will not fit w/K-H disc brakes & all SBP 14X5.5" OE wheels WILL.
Re: Drum vs Disc - rim backspace? [Re: 6bblgt] #1197274
03/23/12 03:42 PM
03/23/12 03:42 PM
busboy Offline OP
busboy  Offline OP
Thank you!
