Steer Me In The Right Direction #1196978
03/14/12 02:17 PM
03/14/12 02:17 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9 V6 216,000 miles. On cold start up, fairly loud metallic sound coming from bottom end. Within 10 seconds or less, quiets down to normal. Been using 20W-50 oil and the consistency is fine, no foreign substances in it. Truck runs great and you will not hear the noise until the next cold start up.
Grandma always said I had "hands of gold"!
Re: Steer Me In The Right Direction [Re: CHRGR69] #1196979
03/14/12 02:19 PM
03/14/12 02:19 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
Oil Pump, its losing prime when not ran for a long time.
Re: Steer Me In The Right Direction [Re: BlakDak] #1196980
03/14/12 02:42 PM
03/14/12 02:42 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Will a high volume pump clear the stock pan and is the pan free from crossmembers?
Re: Steer Me In The Right Direction [Re: CHRGR69] #1196981
03/14/12 02:53 PM
03/14/12 02:53 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
First, change the oil and put a GOOD filter on. One with an anti-drainback valve.
If that doesn't do it, look into going into the bottom end (pump).
Re: Steer Me In The Right Direction [Re: RodStRace] #1196982
03/14/12 03:00 PM
03/14/12 03:00 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I change the oil every 3000 miles and I'm 1000 into this one. Mopar filter on there now.
Re: Steer Me In The Right Direction [Re: CHRGR69] #1196983
03/14/12 03:47 PM
03/14/12 03:47 PM
BlakDak Offline
BlakDak  Offline
That will only create more problems, just get a good oil pump
Re: Steer Me In The Right Direction [Re: BlakDak] #1196984
03/14/12 03:53 PM
03/14/12 03:53 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Standard volume it is. Melling OK??
Re: Steer Me In The Right Direction [Re: CHRGR69] #1196985
03/15/12 02:05 AM
03/15/12 02:05 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The fact that the noise is gone until next cold start kind of means the pump is good. It probably has a bit of extra clearance in the bottom end. I'd leave it.
Re: Steer Me In The Right Direction [Re: buildanother] #1196986
03/15/12 08:17 AM
03/15/12 08:17 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Try a WIX/NAPA Gold filter.
It's Swifty! Swifty, you toad sucker!
Re: Steer Me In The Right Direction [Re: zrxkawboy] #1196987
03/15/12 12:27 PM
03/15/12 12:27 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I'm looking at the WIX 495-51348 filter. I'm not sure if the gray Mopar filters have the anti-drain back valves in them. Also, is the 20W-50 a good viscosity for this application?
