should I get my cam nitrided #1196874
03/14/12 01:29 PM
03/14/12 01:29 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Getting ready to order a new cam after my previous cam failure.
I'm leaning towards a Comp Cams XE275HL.
They offer a nitrided option. At $292 delivered, it doubles the price of the cam.
It's an insurance policy against another wiped cam. Just wondering if it's worth the price.
I'm already getting my lifters direct from Topline Hylift. That should eliminate the possibility of quality issues associated with off shore produced lifters.
I also plan to be a little more selective with my oil choice.
Should I spend another $150 for the nitriding? Worth it,or am I just shoveling another $150 into the hole.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: should I get my cam nitrided [Re: 471Magnum] #1196875
03/14/12 01:42 PM
03/14/12 01:42 PM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
The oil you use will have more to do with your cam success than nitriding...You need to use an oil with lots of ZPPD.
Re: should I get my cam nitrided [Re: 471Magnum] #1196876
03/14/12 01:42 PM
03/14/12 01:42 PM
AndyF Online content
AndyF  Online Content
Probably a good idea these days.
Re: should I get my cam nitrided [Re: 471Magnum] #1196877
03/14/12 01:44 PM
03/14/12 01:44 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
In this case is almost say yes, what could it hurt????
SM does make a hydro lifter, they are costly. Might be worth the read as it covers exactly what you just went through.
I didnt read every post but if this setup failed id not go back to the same, maybe why you ask if you might have it nit.
I find it odd comp offers the nit. option when they know its a problem with there std cams getting trashed, raise the price of ecah cam by X amount, if it really works to make the cam last longer they might make more in the long run....nothing like marketing a sub standard product and then offer a upgrade to make it "correct".
Anyways, good luck, I just use the SM lifters with great results, my only reason to post on them.
http://www.4secondsflat.com/Composite%20lifters.htm
Re: should I get my cam nitrided [Re: 471Magnum] #1196878
03/14/12 01:45 PM
03/14/12 01:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I did it, and I went the with lifters with an oil feed hole EDMed in the face... Was it worth it? I don't know, I've never had a cam fail but with all the failure folks are having these days I felt better spending a little more up front in the hopes I wouldn't be spending allot more later.. So far everything is good...
Re: should I get my cam nitrided [Re: 1_WILD_RT] #1196879
03/14/12 02:02 PM
03/14/12 02:02 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I just ordered a cam custom grind from a well respected cam grinder in my local area and pretty much told him not to hold anything back... Nitride, teflon coating, 4/7, 2/3 swap... what ever he recommends, I'll do it..
He pretty much told me not to waste my money..
Re: should I get my cam nitrided [Re: A57_RT ] #1196880
03/14/12 02:18 PM
03/14/12 02:18 PM
Space Station #5
Space Station #5
The only thing it hurts is my pocket book… this experience has already gravely wounded it.
Regarding those lifters, if I'm going to spend that much to make sure I don't wipe a cam, I'd go roller.
I am inclined to agree that running oil properly formulated for flat tappets is more important. Regardless of whether or not I get the cam nitride, I’m going to be more considerate in that area going forward.
For the record, my cam wipe was probably a brain fart as much as anything. I think I had a bum lifter on which I over did the preload. I may never know exactly why it failed though. Just trying to make sure I do it right... the second time through.
-Jim
Re: should I get my cam nitrided [Re: 471Magnum] #1196881
03/14/12 02:47 PM
03/14/12 02:47 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I had my Comp XTQ296S solid cam nitrided.....more of a piece of mind thing. I'm almost 100% sure that a lot of people and myself included must have spent $150 on less important "frills" somewhere along the line .
My advice is just get it done.
Re: should I get my cam nitrided [Re: superwrench] #1196882
03/14/12 02:52 PM
03/14/12 02:52 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
for all your doing why not go roller at this point?
Re: should I get my cam nitrided [Re: 471Magnum] #1196883
03/14/12 02:53 PM
03/14/12 02:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From my understanding it was a lifter problem and
not so much the cam... so if the lifters are good then
it shouldnt matter... the lifter would fail then in
turn take out the lobe
Re: should I get my cam nitrided [Re: DJVCuda] #1196884
03/14/12 03:04 PM
03/14/12 03:04 PM
Space Station #5
Space Station #5
Plugging a flat tapped hydraulic back in there will cost $250
Roller set-up will cost three times that, or more. Cam, lifters, push rods, bronze gear... shoot that's probably a grand. Not on my budget.
I'm scrounging just to get the motor back together as-is.
-Jim
Re: should I get my cam nitrided [Re: 471Magnum] #1196885
03/14/12 03:06 PM
03/14/12 03:06 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, I, too, had a very expensive rebuild as the result of a flat-tappet cam wiping some years ago and have taken extra measures since then w/ FT cams to try to mitigate that happening again. If spending another $150 at that time to nitride the cam would have reduced the likelihood of that happening in the first place, I would have.
Also, since you can't get an EDM-drilled hydraulic FT lifter, consider grooving the lifter bores or going w/ the special Crower hydraulics that have a small machined flat on the sides of the bodies to allow for more oil getting to the lifter/lobe interface.
One last item... do the HL Comp cams have the same reputation / issue w/ valve train noise & instability as their standard Xtreme hydraulics? If so, I'd suggest looking into what other lobes might be a better choice, unless you're RPM limited already.
Re: should I get my cam nitrided [Re: BradH] #1196886
03/14/12 03:25 PM
03/14/12 03:25 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
If johnson hylift hydros (the maker many companies repackage)these say johnson right on the oil ring but packaged and sold by crane in this case, or the hughes 5003 hydro lifters would help Ive 1 set of each both sets over ten years old NIB (probably better quality material??) would help let me know, id almost give them away if they would fit your needs and budget as I dont use hydo cams anymore if so shoot me a pm.
Also if you consider a roller ive a set of NIB comp rollers and matching gear thats looking for a home for half of new...might make the budget work better for a roller.
Really not trying to sell parts here, I know where the sell section is, I just have this junk and dont need it, it can sit or???
My car budget gets tight at times and NIB parts off here or CL isnt a bad thing if new and fit my needs.
Heck I forgot ive the hughes cam that went with the lifters as well NIB..hughes 3742al also 10 or so years old and the crane hydro is ???? Id have to look.
Re: should I get my cam nitrided [Re: 471Magnum] #1196887
03/14/12 03:27 PM
03/14/12 03:27 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Just in case, since it has not been mentioned, if you are running dual springs remove the inner springs, not the damper, prior to break in. Sorry if this was an useless warning.
The last two flat tappet cams I bought, were Nitrided . I thought of it as an insurance policy. Isn't the price about the same or very little more for the custom grind? I know that they would not do the nitriding without a custom order the last time I ordered.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: should I get my cam nitrided [Re: Hemi Allstate] #1196888
03/14/12 07:59 PM
03/14/12 07:59 PM
Space Station #5
Space Station #5
Not to get off topic, but the cam that wiped was a XE274L. It's a fast rate, but not a high lift. Pretty much the same duration and timing as the XE275HL that I'm leaning towards.
Initially I had a set of J-heads on the motor and ran dual springs, breaking it in without the inners. Turned out the shop that built the heads used the wrong springs and it had something like a 150 lb seat pressure. Somehow I managed not to wipe the cam at that point. Later changed to the correct springs with about 130 lbs seat pressure.
Now I've got the IMM supplied beehives on my RHS heads.
-Jim
Re: should I get my cam nitrided [Re: Hemi Allstate] #1196889
03/14/12 10:33 PM
03/14/12 10:33 PM
Space Station #5
Space Station #5
As explained to me, they can't pull a cam off the shelf and nitride it. Has to be done as part of the grinding process to get the correct surface preparation. So yes, you're effectively paying for a custom ground cam, plus the nitriding process when you go with that option.
-Jim
