4spd Question #119676
09/12/08 08:22 PM
09/12/08 08:22 PM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
Are Truck 4 speeds the same as car 4 speeds? I know where one is behind a big block and was interested in it for one of my cars.
Thanks,
Re: 4spd Question [Re: moposcar] #119677
09/12/08 08:25 PM
09/12/08 08:25 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
No, they are not exactly the same. Is it a granny first gear/top loader 4-speed or an A-833?
The O.D A-833s are very similar between vans/pickups and B/E-bodies, FWIW.
Re: 4spd Question [Re: In_The_Pink] #119678
09/12/08 08:35 PM
09/12/08 08:35 PM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
It is in a 77 4X4 pickup, so I assume it has a granny gear. Not really sure.
Re: 4spd Question [Re: In_The_Pink] #119679
09/12/08 08:37 PM
09/12/08 08:37 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I have a pickup OD and it looks like it has the same tailstock as a B/E, it has two shifter mounts and they appear to be in the exact location as an E body tailstock. Anyone know if they are a bolt in replacement?
Re: 4spd Question [Re: Rapid340] #119680
09/12/08 10:55 PM
09/12/08 10:55 PM
IMGTX Online content
IMGTX  Online Content
Yes the 833's tranny's are a bolt in replacement for 70 and newer B/E bodies but like pink said the Granny gear 4 speeds are not the same and will not fit.
The bearing retainer size is larger on the OD833's than on the early model non overdrive 833 and more often than not the rear shifter mounting pads are not drilled and tapped. Those are easy fixes.
A/F bodies used a shorter tranny than the trucks/vans.
Re: 4spd Question [Re: IMGTX] #119681
09/13/08 12:18 AM
09/13/08 12:18 AM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
Thanks for the replies.
Re: 4spd Question [Re: IMGTX] #119682
09/13/08 12:58 AM
09/13/08 12:58 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Uhmm, if memory serves, only the 2wd trucks got the 833 o/d trans(will bolt into a b/e body once you deal with the different bearing retainer size) and the 4x4's got the NV series toploader trans which are not even close to fitting into anything else, nor would you want to use one in a performance build.
