Converting pushbutton transmission.. #1196777
03/14/12 02:56 AM
03/14/12 02:56 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
I recently picked up a Mopar with a pushbutton TF and the trunion style yoke. Thaty yoke is not in very good shape and is missing it's "dust boot". Can these cars be converted to a later style slip joint yoke, if so what is required? Or do I need to toss the trans and move on?
Re: Converting pushbutton transmission.. [Re: Al_Alguire] #1196778
03/14/12 03:39 AM
03/14/12 03:39 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
You need the tailhousing and oupput shaft from a 65 only transmission.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Converting pushbutton transmission.. [Re: HemiRick] #1196779
03/14/12 05:13 AM
03/14/12 05:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You need the tailhousing and output shaft from a 65 only transmission.
The '65 had the slip yoke, rear pump, and cable shift / cable park.
I think it would be easier to take a newer 727 and adapt the pushbutton cable to work the newer shift lever?
Re: Converting pushbutton transmission.. [Re: Al_Alguire] #1196780
03/14/12 08:43 AM
03/14/12 08:43 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Ditch the trunion-unit and have a driveline shop make you a driveshaft like they did for me.
Bolts right up to the transmission flange.
Re: Converting pushbutton transmission.. [Re: Al_Alguire] #1196781
03/14/12 09:27 AM
03/14/12 09:27 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Hemi cars through 1964 had them. 4 speed cars through 1965 did too. The ball and trunnion setup is pretty darn strong and maintenance free. The boot is really about all that goes bad. Of course the resulting loss of grease would be the killer. I am using a '65 904 trans in my 360 powered '65 Dart bracket car. Still have the ball and trunnion setup. No problems even running drag radials, a bit higher stall, and Cheetah VB.
Re: Converting pushbutton transmission.. [Re: rbstroker] #1196782
03/14/12 09:43 AM
03/14/12 09:43 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree the B&T is strong.My 65 4 speed still runs the OE one.Ive broken a bunch of rear joints but never had problems with the frt.I see kits on Ebay for usually about 60 bucks.Rocky
Chrysler Firepower
Re: Converting pushbutton transmission.. [Re: therocks] #1196783
03/14/12 10:33 AM
03/14/12 10:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I went to the newer 727 in my 63 without the rear pump. Then I just had a driveshaft made. I think Imperial Service makes a kit that you can use the newer 727 work with the push buttons. I just slapped a floor shifter in mine but I want to go back to the push buttons as they are so cool. Ron
Re: Converting pushbutton transmission.. [Re: 383man] #1196784
03/14/12 11:51 AM
03/14/12 11:51 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
there are several bolt on yokes that fit including the one on a cummins torqueflite 2wd tranny---bob
Re: Converting pushbutton transmission.. [Re: savoy64] #1196785
03/14/12 04:46 PM
03/14/12 04:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Al, regardless of which rear set-up you use I would a later front pump and wide bushing drum. That way you can use any late converter. The rest of the parts hold up fine in a 10.0 application. We'll see how the input and output shafts hold up in a low 9 second application soon. By the way the 65 tail shaft and extension housing can be either big or small block.
Doug
Re: Converting pushbutton transmission.. [Re: 383man] #1196786
03/14/12 10:49 PM
03/14/12 10:49 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Be very, very, wary about sending them anything, money or parts!
My friend who sent them both only recently got some of his parts and money back, after waiting a loooong time, and some conversations with attorneys.
He has given up on them. I suggested a 65 case, but he is going 4spd now.
It takes gasoline to interest me.
Re: Converting pushbutton transmission.. [Re: VL21] #1196787
03/15/12 11:54 AM
03/15/12 11:54 AM
Las Vegas
Las Vegas
Thanks for the info guys. At thsi point not sure what I will do. We may just jump right to redoing the entire car and not worry about the current drivetrain. Just wanted to drive it a bit with the pushbutton set up, but maybe we will just pull the 318 and pushbutton trans and begin the transformation into........
