8-3/4 Third Member Help #1196615
03/13/12 09:29 PM
03/13/12 09:29 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I pulled the 489 center section out of the T/A yesterday and learned to my displeasure that it has an open 3:23 chunk in it. Can someone point me to a tech article or other source that can get me smart before I start my hunt for a replacement?
Thanks!!
Re: 8-3/4 Third Member Help [Re: floyd] #1196616
03/13/12 10:00 PM
03/13/12 10:00 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I'm dealing with a friend who just tore up his $500 Detroit locker if that will help. I'm trying to dig up enough parts to put him together an OEM 68 down clutch type. They are rebuildable with replaceable clutches. The style that would have come in your car is a cup and cone type that is not rebuildable per say. When they start to slip, you can have the housing machined off a little and they work again. Good used parts are what I would look for. Back in the day when mopar was dumping all their spare parts for nothing, I bought 4 NOS cup and cones for 25 each! Saving the last one for my Son's R/T.Check the differential section here on Moparts.
Re: 8-3/4 Third Member Help [Re: fastmark] #1196617
03/13/12 10:31 PM
03/13/12 10:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
if you want factory,,, get a clutch style unit from a 741 or 742 diff. if you want something better that that get ahold of Dr Diff here on the board.
I am truckless..
Re: 8-3/4 Third Member Help [Re: 340SHORTY] #1196618
03/14/12 09:44 AM
03/14/12 09:44 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks to both of you. I'll check with Dr. Diff. A local salvage yard has several SG chunks in their warehouse. I wanted to see what style to look for before I check them out. The clutch-style has the small coiled springs visible in the SG unit right?
Re: 8-3/4 Third Member Help [Re: floyd] #1196619
03/14/12 10:31 AM
03/14/12 10:31 AM
Missouri
Clayton Offline
Clayton  Offline
Missouri
No the clutch type has no visible springs
Re: 8-3/4 Third Member Help [Re: floyd] #1196620
03/14/12 10:51 AM
03/14/12 10:51 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Okay, I think I have it figured out
clutch type
Re: 8-3/4 Third Member Help [Re: floyd] #1196621
03/14/12 10:51 AM
03/14/12 10:51 AM
MD
floyd Offline OP
floyd  Offline OP
MD
cone
Re: 8-3/4 Third Member Help [Re: floyd] #1196622
03/14/12 10:51 AM
03/14/12 10:51 AM
MD
floyd Offline OP
floyd  Offline OP
MD
open
Re: 8-3/4 Third Member Help [Re: floyd] #1196623
03/14/12 11:36 AM
03/14/12 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes you got it , do yourself a huge favor and avoid the cone .
Re: 8-3/4 Third Member Help [Re: JohnRR] #1196624
03/14/12 02:39 PM
03/14/12 02:39 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Your TA would have come with the 489 case with the cone style sure grip. I would get a new or used power loc (clutch type) and correct gear ratio for your car (could only be 3.55 or 3.91 and only listed on the BS) and then use the 489 case you already have. If the 489 case you have is '72 or '73-up, it probably won't be machined for 3.91 gears if that is what you need. But, you can grind the clearance needed with a little effort.
Re: 8-3/4 Third Member Help [Re: 70440+6bbl] #1196625
03/14/12 03:01 PM
03/14/12 03:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know there was a difference .
Re: 8-3/4 Third Member Help [Re: JohnRR] #1196626
03/14/12 05:10 PM
03/14/12 05:10 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
thats news to me..
I am truckless..
Re: 8-3/4 Third Member Help [Re: 340SHORTY] #1196627
03/14/12 05:35 PM
03/14/12 05:35 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I've read that the MP aluminum chunk needed to be machined in the pinion area for gears taller than 3.55. I've never heard of an iron case needing work to fit gears.
Re: 8-3/4 Third Member Help [Re: Kern Dog] #1196628
03/14/12 05:44 PM
03/14/12 05:44 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
It wasn't all of them, but many were like that. I first read about it in a Mopar Action article years ago ( Rick E)and then experienced it first hand several years ago. Actually, HPMike is the one that set that chunk up for me. Maybe he'll chime in and share his experience.
Re: 8-3/4 Third Member Help [Re: 70440+6bbl] #1196629
03/14/12 06:05 PM
03/14/12 06:05 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I read the M/A article too. I'm sure that the housing that had trouble was the aluminum unit. Aluminum ANYTHING needs to be thicker than steel or iron to have equal strength.
Re: 8-3/4 Third Member Help [Re: Kern Dog] #1196630
03/14/12 09:25 PM
03/14/12 09:25 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks for all the replies. the quest has begun.
