Who has replaced a front frame rail on a 71 A body? #1196587
03/13/12 08:38 PM
03/13/12 08:38 PM
Woodbridge NJ
E
ev2mopar Offline OP
ev2mopar  Offline OP
E
Woodbridge NJ
So I was poking around on my 71 Dart the other day, and crept down to peek at my left front tire.
well, wouldn't ya know it? A pretty small, but still there, rot hole. Its around 2 inch in diameter. I am pretty confident that if I start grinding away to patch, there will be more.
So my question is this...who has replaced a frame rail on an A body? Should I just bring it to a good body shop...whom will probably rake me over the coals in pricing.
Keep on mind this a grandma fresh 198ci Dart with some sheetmetal rust. Definently not a high dollar car.
I appreciate any ideas you guys can offer.
Re: Who has replaced a front frame rail on a 71 A body? [Re: ev2mopar] #1196588
03/13/12 08:50 PM
03/13/12 08:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Looking at it from a NON restoration standpoint, I'd say to cut and patch the area. To replace the rail, EVERYthing comes out....Engine and trans, K member, front suspension.....Pretty big job. If the car is due for a total restoration, its just another task to do.
Re: Who has replaced a front frame rail on a 71 A body? [Re: ev2mopar] #1196589
03/13/12 10:29 PM
03/13/12 10:29 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
It is a big job I've done both on a 67 satilite pretty much the same job. If its not a 100 point car just patch it. If it gets to the point where its causing trouble then you have a big dission on your hands.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
