LED Taillight bulbs? #1196527
03/13/12 06:39 PM
03/13/12 06:39 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I was considering a switch to the LED bulbs. I saw some at a local "speed shop" and they were priced at $10 each. The Charger takes 4 1157 syle and 2 1057 for the inners. I may be wrong on the inner #. Is that a decent price? It seems that $60 for taillight bulbs is a little steep. I dont mind spending a LITTLT more, but 10 times the price???
Are there other options? Thanks!
Re: LED Taillight bulbs? [Re: Kern Dog] #1196528
03/13/12 06:45 PM
03/13/12 06:45 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
10$ a bulb is about average for LED bulbs. Heck, I have seen LED bulbs that run upwards of 45$ a piece on Summit!
They aren't a cheap upgrade relative to what they replace (99 cent bulbs) and I am on the fence myself if i should invest on LED on my Charger or not....I have heard mixed reviews on them.
If you do go with them, I'd be interested to hear what you think of them.
Re: LED Taillight bulbs? [Re: cjskotni] #1196529
03/13/12 06:58 PM
03/13/12 06:58 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
In my opinion, the small replacement bulbs for tail lights won't cut it. LEDs are very directional lighting and it will get lost in most of our housings.
I bought trailer lights and adapted..
http://www.cuda-challenger.com/cc/index.php?topic=67744.msg695422#msg695422
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: LED Taillight bulbs? [Re: GoodysGotaCuda] #1196530
03/13/12 08:26 PM
03/13/12 08:26 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I actually did a comparison on my 69. I show the differences between bayonet style LED bulbs, incandescents, and also the PCBs. I use the PCB. Hyper White...Red just doesnt cut it for me. The Hyper whites are stupidly bright. I have the two outer "sections" on a Hi-Lo. and the inner most of each on a Lo. I have 432 rear facing LEDs and the shadow behind (where the factory bulbs went) I placed six 36LED RED 1156/1157s to place a red tint effect wired in with the brakes.
http://www.youtube.com/v/2Rz7NTJtL2o
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: LED Taillight bulbs? [Re: Pyper70] #1196531
03/13/12 09:53 PM
03/13/12 09:53 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I agree with Pyper and Goody. Forget adding straight up replacement LED bulbs in LARGE tail light housings. You will waste money and not be happy with the results. If you have small tail lights like a '68 Barracuda or '71-'73 Swinger then you will be okay just upgrading bulbs without getting fancy.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: LED Taillight bulbs? [Re: GO_Fish] #1196532
03/17/12 02:54 AM
03/17/12 02:54 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
I was happy with the leds in my small housings on my 69 RR. I switched almost all of the lights in my car to leds. I did have a issue with the led for the dome light. I found out the hard way and toasted my dimmer switch.
Leds can be dirt cheap if you don't mind waiting a couple weeks for them.
Red_LEDs
Re: LED Taillight bulbs? [Re: Big_E] #1196533
03/17/12 03:04 AM
03/17/12 03:04 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I saw a link in another post on DodgeCharger.com. Some guy makes LED boards to fit inside the housings, and also has a sequential turn signal option! They are significantly brighter, but the kit costs $300. I think I'd be better off buying the Bilstien shocks instead.
Re: LED Taillight bulbs? [Re: Kern Dog] #1196534
03/17/12 11:22 AM
03/17/12 11:22 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Re: LED Taillight bulbs? [Re: Kern Dog] #1196535
03/17/12 11:28 AM
03/17/12 11:28 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Like Scott mentioned, the plug-in replacement LED bulbs work great in the `68 Barracuda tail light. The bulbs I bought were found on e-Bay for about $10 a pair. I used the barrel-style w/LED's around the edge for more light-dispersion in the small housing.
The seller's name is Sylvia-biz.
http://stores.ebay.com/Sylvia-biz-Store/...1513&_pgn=2
As for the actual installation, you must match the rest of the circuit with LED's. You also have to use an electronic flasher as the old bi-metallic type will not operate. I installed LED's in the tail/brake lights and front parking/directional's and they work & look great.
* While your at it add a third brake light using LED's too. I tapped into the Barracuda's brake light switch before the directional switch and ran it to a high mounted billit aluminum street rod style lamp. I attached it to the upper rear headliner lip and tucked the wires under the inner weatherstrip for the window. Looks great at night and is VERY effective.
`68 Barracuda 340-S
Re: LED Taillight bulbs? [Re: FASTBACK340] #1196536
03/17/12 11:42 AM
03/17/12 11:42 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
I dont think its been mentioned yet, but there is a trade off for the leds, esp on a fresh resto with NOS parts.
Even if the leds are not up to spec they will not heat up and increase the rate your lenses fade/crack.
Grab a 1157 with your fingers and have one hit the brakes, its all heat....
Re: LED Taillight bulbs? [Re: Big_E] #1196537
03/17/12 01:15 PM
03/17/12 01:15 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
What exactly did you do with the dome that we all should learn from? I haven't changed my dome light yet. I have the front turn signals in the valance in (Amber), I have the reverse lamps in (Hyper White), the license plate light (Warm White), the trunk light is another PCB (Hyper White). I installed bi-directional LEDs in the dash for illumination, turn signals, e-brake, console shifter. (cool white)
I can't find anything to fit in the console courtesy lights though. I might have to change the pigtail out and put another bulb in there. Those are the ones you want a definite LED in there. A regular bulb will burn a hole right through the lens if you have your door open for a while. Also can't find anything to fit the hood turn signals for the Charger.
Re: LED Taillight bulbs? [Re: Pyper70] #1196538
03/18/12 02:52 AM
03/18/12 02:52 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
The 1004 led blubs that I bought have one major flaw, they were all grounded to the metal case. If you use the blub as new, chances are you will fry your dimmer switch AND a fuse.
To fix any problems you have to un-solder the two bottom contact areas & take the top off the blub. Don't pull too hard because there is a line soldered to the metal case. Un-solder that line. You may have to lengthen it for the next step. Now just reassemble & re-solder the two lines to the bottom contacts. Then use a real good glue, I used Gorilla Glue, to keep the two halves together.
Also, maybe because the bases are different from the OE blubs, I blew a fuse the first time when I left my door open to put the blub in. So either solder in a old base or just make sure you have no power going to your socket when you install your new led blubs. This was before I found out about the grounded case so that may have been the problem all along.
You could buy some leds and use the bases from your old blubs to make any special blubs you need. I used a small panel and a old base for my map light. It is crazy bright! I have seen round panels that would work perfect for the console lights.
Re: LED Taillight bulbs? [Re: Big_E] #1196539
03/19/12 12:07 AM
03/19/12 12:07 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I upgraded to LED's in the Waygun.
I use the 360 degree bulbs to ensure full lighting of the housing.
They cost more,but look and work better.
For best results,use an electronic flasher and load resistors for the turn signals.
superbrite led and Putco sells them.
http://www.superbrightleds.com/
http://www.putco.com/products.cfm?action=ProductView&Id=9ac2e07b-df8c-1992-9078-7540c16dd87f
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
