26" B-Body Radiator Shroud Mount? #1196402
03/13/12 03:02 PM
03/13/12 03:02 PM
Flint, MI
Gusteve Offline OP
I Love the Unicorn Song!!
Gusteve  Offline OP
Flint, MI
Hey All,
I need to buy a shroud for my 68 440 Charger but I'm confused. The standard part # P2785434 looks like this:
It has three mounting holes on one side, and two on the other.
My radiator has 4 mounting points in a square. It looks like it wants something like this:
But that pic is for a 22" shroud that requires a mounting kit.
The car was originally a 318, and had the 440 installed sometime back in the 1980's. The engine came from a '73 something, and I have no idea what the radiator is, except that it is 26" across the core.
Will the standard part # bolt up good enough even though all the holes won't match up? Or do I need something else?
Also - I was thinking about using the 30% off from YO for the shroud, which makes it $70+$30 shipping. Could I get it cheaper anywhere else?
Thanks!
Re: 26" B-Body Radiator Shroud Mount? [Re: Gusteve] #1196403
03/13/12 03:24 PM
03/13/12 03:24 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The top one is the proper one for your car IF it had the correct radiator, it does not. In 1970 it changed the 4 bolt design similar to the bottom photo, that is the one you want to get to put on the radiator you have .
Re: 26" B-Body Radiator Shroud Mount? [Re: JohnRR] #1196404
03/13/12 04:04 PM
03/13/12 04:04 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
Thanks.
I was thinking maybe that whatever car from '73 donated the engine probably also donated the radiator.
Too bad for me the '70 up costs another $30 or so.....
Thanks again.
Edit - looks like its <$90 locally from Mancini or RosevilleMoparts.
