Hey All,
I need to buy a shroud for my 68 440 Charger but I'm confused. The standard part # P2785434 looks like this:
It has three mounting holes on one side, and two on the other.
My radiator has 4 mounting points in a square. It looks like it wants something like this:
But that pic is for a 22" shroud that requires a mounting kit.
The car was originally a 318, and had the 440 installed sometime back in the 1980's. The engine came from a '73 something, and I have no idea what the radiator is, except that it is 26" across the core.
Will the standard part # bolt up good enough even though all the holes won't match up? Or do I need something else?
Also - I was thinking about using the 30% off from YO for the shroud, which makes it $70+$30 shipping. Could I get it cheaper anywhere else?
Thanks!
