Thermo-Quad POP #1196309
03/13/12 11:39 AM
03/13/12 11:39 AM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
When you slam it open from idle, you get a real big POP from the secondaries. Off idle is OK. Air door is several turns tighter on the spring that normal adjustment. Didn't seem to help. I can bump the timing some I think. It's been so long since I set it, don't know where it is. It's probably at least 36 total, don't know initial. Car is sold,
I need to fix this.
Suggestions?
Thanks,
jim.
Re: Thermo-Quad POP [Re: bacaruda] #1196310
03/13/12 02:19 PM
03/13/12 02:19 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
It may have a lean spot just for a split second. Try adjusting the door the opposite way with maybe only one turn of the spring.
There is a good thread on here regarding secondary door adjustment in relation to the choke pull-off. Read here: https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Thermo-Quad POP [Re: Dave Watt] #1196311
03/24/12 11:50 PM
03/24/12 11:50 PM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
The pull-off adjustment did it. I didn't experiment, put it at no clearance. Maybe not best, but presentable for sale.
Thanks,
jim.
Re: Thermo-Quad POP [Re: bacaruda] #1196312
03/25/12 07:49 PM
03/25/12 07:49 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I'm learning more about Thermoquads too, glad to help.
