2 lbs oil pressure at hot idle, acceptable? #1196181
03/13/12 03:05 AM
03/13/12 03:05 AM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
OK guys,
Got tired of seeing the idiot light on the Van on and the gauge dropping to nothing at hot idle so I pulled the doghouse and attached a mechanical gauge and ran it to see what was going on.
Wee when I cold started it it was at 45 at idle, over 50 down the road. Once it warmed up then it dropped to TWO pounds of pressure at idle. You could watch the line getting clearer and clearer. Down the road hot (No overdrive, 3.55 gears) it runs around 30-35 at 65-70.
So it confirmed my suspicions, its getting very little pressure warmed up idling, in gear or out. At highway speed there is a roar coming from the engine but it still has that 30-35 lbs pressure. let up and it goes away.
Once its revved a little then it jumps back up to around 25-30 depending on RPM. I am running 10W40 oil.
So, is my pressures okay or am I in danger of grenading the motor anytime soon? I know they are low but I would like to limp it along till my other truck is running.
I also pulled the breather and inside the baffle it was all gunked up. Probably a pennzoil motor.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196182
03/13/12 03:09 AM
03/13/12 03:09 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
No no no no no no no nononononononono. 2 pounds isn't even a normal fuel pressure much less oil pressure.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196183
03/13/12 03:11 AM
03/13/12 03:11 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Say WHAT
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: A57_RT ] #1196184
03/13/12 03:22 AM
03/13/12 03:22 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Only chevy small blocks will work with 2 psi...
Try some thicker oil, 20w 50 next oil change and see if makes any difference..
An oil pump change may help as well.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: sthemi] #1196185
03/13/12 07:55 AM
03/13/12 07:55 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
With that little pressure you lifters should be on the very edge of rattling or not rattling. Likely loose main bearings causing low pressure.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196186
03/13/12 09:10 AM
03/13/12 09:10 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196187
03/13/12 09:32 AM
03/13/12 09:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
DUde that thing is done. not sure what you can do at this point.
Coming soon!!!!
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196188
03/13/12 09:34 AM
03/13/12 09:34 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
either an extremly worn out oil pump ( not liklely)
or the bearings are done, time for a rebuild
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: gtx6970] #1196189
03/13/12 10:13 AM
03/13/12 10:13 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You could drop the pan and swap in some new standard bearings. New oil pump while your in there. Might get you down the road for a while.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: bobby66] #1196190
03/13/12 10:35 AM
03/13/12 10:35 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
Just a thought (I've seen it before) If it had a timing chain with the plastic gear go away and valve seals got hard and broke up, chances are the oil pump pickup could be plugged. You might get by just pulling the pan and cleaning the pickup screen.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: Mike P] #1196191
03/13/12 11:24 AM
03/13/12 11:24 AM
drop the pan and change out the pickup screen & a hi vol pump if that dont do it then some 50 wt racing oil
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: RapidRobert] #1196192
03/13/12 11:28 AM
03/13/12 11:28 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
cam bearings? Any glitter on the dip stick?
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: Mr.Yuck] #1196193
03/13/12 11:32 AM
03/13/12 11:32 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
I had one like that, ran it for about a year in the garage while fixing misc other stuff. It always had good oil pressure even while hot. Then I took it for a test drive, and the oil gauge would drop to zero at stops. Pulled the engine, pulled it apart, found it had chewed up a bearing or two. Your motor's dead. Don't waste money on thicker oil, it won't help.
Everybody makes fun of a hillbilly until they need something fixed
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196194
03/13/12 12:17 PM
03/13/12 12:17 PM
Detroit, Michigan, USA!
peelerboy Offline
peelerboy  Offline
No, that pressure is not okay and yes, you are in danger of grenading the engine sometime soon.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: peelerboy] #1196195
03/13/12 12:48 PM
03/13/12 12:48 PM
Upper Midwest
Upper Midwest
I can't believe that the lifters aren't rattling at idle with that little pressure.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoparforLife] #1196196
03/13/12 12:55 PM
03/13/12 12:55 PM
peelerboy Offline
peelerboy  Offline
You and me both.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196197
03/13/12 12:59 PM
03/13/12 12:59 PM
Try another gauge first before doing anything else At that pressure all of the hydraulic lifters should get noisy after idling a very small amount of time, let us know what you find
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196198
03/13/12 01:05 PM
03/13/12 01:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Check the oil to see if it smells gassy and feels alright!
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196199
03/13/12 01:08 PM
03/13/12 01:08 PM
Spring Mount, PA
MOPAULY Offline
MOPAULY  Offline
Spring Mount, PA
Minimum 10lbs per 1000 rpm Jamie.
Re: 2 lbs oil pressure at hot idle, acceptable? [Re: MoPar Jamie] #1196200
03/13/12 01:18 PM
03/13/12 01:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have a 1983 International 4X4 truck with a 345 gas V-8 engine. It is a old ultities company truck with a 7.5 ton crane on it.
I bought it about 15 years ago just for the crane and the truck came with it.(that's what the dealer told me)
I figured I could rebuild the engine since I had rebuilt other International gas engines.
This engine has no oil pressure at idle, as soon as you rev it 100-200rpm the gauge moves.
This truck is geared real low and screams out on the road, hi rpms.
It's still running with no work done to it now for over 15 yeras.
No we don't drive it 8 hours a day, but we did for like 10 years. It mostly sit's nowadays but has never gave up and it has almost no oil pressure at idle.
Now I did rebuild the trans twice and the transfer case once, but never the engine. lol
To the OP, I say drive it until it dies, it might be a long time from now?
