360 la cam choice #1195927
03/12/12 09:17 PM
03/12/12 09:17 PM
NEW JERSEY
TLEARN 23 Offline OP
NEW JERSEY
I have a stock 1978 360 in my 71 dart. it runs nice. I'm looking to optimize what i have if possible with a cam change. presently drive train utilizes a performer intake, 700 holley vacc secondary, tti headers, 2000-2500 stall and 3:55 posi. compression 8.5. any cam suggestions would be appriciated.
Re: 360 la cam choice [Re: TLEARN 23] #1195928
03/12/12 10:55 PM
03/12/12 10:55 PM
scratchnfotraction Offline
Hughes 'whiplash' cam works with the lower comp ratio and sounds nasty but very street friendly to cruz around with.
would work nice with that combo. IMHO
I have used the lunati bracket master 292/292 in a combo very close to yours with good results also.
I like the whiplash much better though.
Re: 360 la cam choice [Re: TLEARN 23] #1195929
03/13/12 02:23 AM
03/13/12 02:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Hughes HEH1523AL is a good performing cam for a mild engine. I have it in the 360 that I built for my RamCharger 4x4.
If the Hughes cam/lifters are too pricey, the Lunati Voodoo 60401LK would be a good cam, for about $100 less. With your low compression and stock heads it may even be a better choice since it is slightly shorter duration.
The cams above will perform well with a near stock idle. Good low/mid range power from about 1,000-5,000 RPM. These cams are easy to live with in a daily driver.
If your looking more for a hot street/strip cam, then you may want a slightly hotter cam. The larger of a cam you go with, the more the low end torque will fall off unless you do something to increase the compression ratio.
Re: 360 la cam choice [Re: 451Mopar] #1195930
03/13/12 09:56 AM
03/13/12 09:56 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
comp XE262 worked good for me in a similar combo
2017 Grand Cherokee Overland
