I've searched all over the internet, and i swear that every post i came to asking this questions had 10 answers. And there all different!
Anyway i've got my crank at the shop getting its main's turned down and i want them to drill the hole deeper if it needs it.
It has a pilot bushing in it, but i don't want any surprises when i get the bellhousing and am ready to put it all together.
The outside diameter of my pilot bushing was about 0.9" and the hole from the end of the pilot bushing is about 1.7" deep with a slight taper at the end.
will this clear the transmission shaft, because i refuse to cut the the input shaft?
thanks
-Lucas
