Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? #1195830
03/12/12 05:59 PM
03/12/12 05:59 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
OK...For a 72 Challenger, brother has a 4 pulley setup that bolts to the balancer? (pardon me If I get something wrong here....I don't know much about the engines, etc .....just like to drive them....lol)there is another pulley above it....I think he said it's for the altenator.....well the top pulley and the 4 pulley's below just hit each other.....so I guess the real question is.....is the 3 pulley setup the one we need???? he thinks the 4 pulley setup is from a New Yorker or something similar.....AND....Does anybody have the 3 pulley assembly for sale?? Thanks...Anyone have some good pics?? I don't have a pic yet of what he has yet......Thanks again for any help....Tony
Finally Done....BEERS!!!
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: holtzdog55] #1195831
03/12/12 07:05 PM
03/12/12 07:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
My head hurts .
The pulley above the crank is the water pump , to the left ... looking at the engine ... is the altenator , to the right is power steering if he has it . does the car have A/C.
If no A/C and he has power steering he needs a 2 crank pulley and the correct water pump pulley , no A/c and no power steering a 1 groove crank pulley and the same as the 2 pulley water pump pulley .
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: JohnRR] #1195832
03/12/12 08:04 PM
03/12/12 08:04 PM
Fairfield, Ohio
Fairfield, Ohio
My head hurts .
My head hurts too....lol
It will have A/C eventually....does have power steering......I would have to see a pic to at least be able to see what I would actually need for it to be correct......
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: holtzdog55] #1195833
03/12/12 08:16 PM
03/12/12 08:16 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: holtzdog55] #1195834
03/12/12 08:41 PM
03/12/12 08:41 PM
scratchnfotraction Offline
My head hurts .
maybe this helps,its a non a/c with ps... 3 groove crank pully,2 groove wp pully,1 groove alt pully
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: scratchnfotraction] #1195835
03/12/12 11:16 PM
03/12/12 11:16 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
72 New Yorker with AC
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: CYACOP] #1195836
03/13/12 01:39 AM
03/13/12 01:39 AM
JohnRR Offline
JohnRR  Offline
This one is missing a belt , there should be 2 on the A/C - altenator .
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: JohnRR] #1195837
03/13/12 07:09 AM
03/13/12 07:09 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Correct
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: Tom_440] #1195838
03/13/12 08:57 AM
03/13/12 08:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You might check this out:
http://bouchillonperformance.com/BigBlockEngines.asp
This is who I got pulleys from, everything fit first try after I mearsured something for JR, he knew exactly what I needed.
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: Challenger 1] #1195839
03/13/12 09:36 AM
03/13/12 09:36 AM
Fairfield, Ohio
Fairfield, Ohio
Thanks for the pics guys....I'll get him to look at these and the site.....
Gary....is that the way it should be with A/C??
Re: Pulley setup on 440- 3 pulley's?? 4 pulleys?? Pictures? [Re: holtzdog55] #1195840
03/13/12 09:52 AM
03/13/12 09:52 AM
Cincinnati, Ohio
Cincinnati, Ohio
Bouchillon has 2 choices for sandon compressor mounts, one up high like mine and another down low where the fuel pump would normally be(can't use a mechanical pump) that hides the compressor.
