69 Bee rear window trim removal #1195739
03/12/12 03:38 PM
03/12/12 03:38 PM
Plymouth, MI
HotRod20 Offline OP
HotRod20  Offline OP
Plymouth, MI
Anyone have a best practice to remove front and rear window trim? I was looking for a B body restoration book to refresh my memory. Last full resto I did was in '87.I was hoping a book might be out there that has a pictorial on this.
Re: 69 Bee rear window trim removal [Re: HotRod20] #1195740
03/12/12 09:47 PM
03/12/12 09:47 PM
PEI Canada
chromedome426 Offline
PEI Canada
There is a proper tool that just slides between the glass and the trim. Once you hook the tip of the tool behind a clip gently pull the clip away from the outer edge of the trim. Then gently pull the trim up from the glass just enough to clear the clip. Let the tention off that clip and move the tool to the next one. Hope that helps you.
Re: 69 Bee rear window trim removal [Re: HotRod20] #1195741
03/12/12 10:03 PM
03/12/12 10:03 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
You need the trim tool that looks like an arrowhead. I tried a GM/Ford/AMC tool (like the one shown above) on my '71 Dart and got frustrated, but the right tool pops the clips in a jiffy with no hassle. Found mine at an O'Rielly Auto Parts store that carries paint supplies, no local paint shops knew what tool I was talking about.
Not sure if a B-body has the same clips as an A-body. If it does this thread will help, has a pic that shows what the tool looks like. trim removal
Re: 69 Bee rear window trim removal [Re: 300by500] #1195742
03/13/12 09:49 AM
03/13/12 09:49 AM
Plymouth, MI
HotRod20 Offline OP
HotRod20  Offline OP
Plymouth, MI
Hey thanks to the both of you,this info is great. I will get the tool and have at it. Thank you so much for the pictorial link. That is awesome and will probably be used by others to follow.
I love this site.
HR 20
Rich
Re: 69 Bee rear window trim removal [Re: HotRod20] #1195743
03/13/12 10:01 AM
03/13/12 10:01 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I love this site.
HR 20
Rich
As noted in the pic link be aware of the tar like sealer that may have the trim stuck even after the clips are released. It's very easy to bend if your not careful. Ask me how I know. Good luck.
