Hood tachometer #1195619
03/12/12 10:10 AM
03/12/12 10:10 AM
Baton Rouge, LA
SethJof Offline OP
SethJof  Offline OP
Baton Rouge, LA
I have an old hood tachometer that I haven't seen work. I believe it's a Dixco tach and it has three wires: red, black and green. Does anyone know if the 3-wire Dixco tach had its own light (powered by those 3 wires)? I found an old Moparts posting talking about hood tachs and I think someone said the older tachs had 3 wires while the newer tachs had 4 wires. I didn't see any mention of illumination in that old posting, though.
thanks
Re: Hood tachometer [Re: SethJof] #1195620
03/12/12 04:41 PM
03/12/12 04:41 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Pretty sure that you need the 4th wire - seperate circuit for lighting.
Should have one for ground, one for power, one for coil and one for light.
Just off the top of my head . . .
Cheers
Mark
Re: Hood tachometer [Re: a12rag] #1195621
03/12/12 05:08 PM
03/12/12 05:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Some old tachs used the power wire to light them and when you turned on the key the light was on. You could just hook up the black and red wires to a battery and see if the tach lights.
