Race car wiring harness?
#1195568
03/12/12 08:10 AM
03/12/12 08:10 AM
Posts: 2,936 Finalnd, Perkele
jyrki
Finalnd, Perkele
Is there any "universal wiring harness" available to wire a tube chassis drag race car? Don't need any "street properties", but MSD, nitrous set up, trans brake etc.
Plynouth VIP '67 TT IC EFI
Re: Race car wiring harness?
[Re: 68roadrunner]
#1195571
03/12/12 11:30 AM
03/12/12 11:30 AM
Posts: 19,690 Las Vegas
Al_Alguire
Las Vegas
Speedwire and Spaghetti Menders both make great stuff. Both are totally customizeabel as well.
[Re: jyrki]
#1195572
03/12/12 04:28 PM
03/12/12 04:28 PM
Posts: 35 Mi USA
Dyno Donnie
Mi USA
Most chassis cars would be a custom wire job. Try Race car Solutions. Brian Black Just built me a nice 16" X 16" custom board for my chassis car. Three main wires filled with each individual wire lead one wire to accessory- one to switch panel-one to MSD bo wwwracewiresolutions.comx
[Re: Dyno Donnie]
#1195573
03/12/12 05:42 PM
03/12/12 05:42 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
His panels are awesome....
I built my own...Not a very good pic, but you get the idea
[Re: Dyno Donnie]
#1195575
03/12/12 07:50 PM
03/12/12 07:50 PM
Posts: 323 Maryland
Bill_G
Maryland
I just ordered a custom panel from Brian, similar to this one. Bill Quote:
1970 Charger R/T 1970 Dart Swinger 340/4spd
[Re: Bill_G]
#1195576
03/12/12 09:29 PM
03/12/12 09:29 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I am a Spaghetti Menders authorized dealer/installer and I highly recommend their products. www.spaghettimenders.comBob Lapp of Spaghetti Menders uses a floating ground vs. chassis grounds. Single stage nitrous, clutch car wiring pic
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: HEMIFRED]
#1195580
03/13/12 07:41 PM
03/13/12 07:41 PM
Posts: 6,191 Melbourne , Australia
LA360
Please forgive me for asking a stupid question (I have very, very little knowledge with things electrical), but how do these panels work? I am assuming there is a common buzz bar to a lot of those terminals?
Alan Jones
[Re: LA360]
#1195581
03/13/12 07:50 PM
03/13/12 07:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would assume it has a major single input.... I'm lookin for a fuse and relay panel for my Rampage... I want to move the fuse block/relays to behind the seat... havent seen what I want yet... probably will end up making it
[Re: Bill_G]
#1195582
03/13/12 07:55 PM
03/13/12 07:55 PM
MR_P_BODY
Bill is that a real plate of carbon fiber... looks good
[Re: LA360]
#1195583
03/13/12 08:15 PM
03/13/12 08:15 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
this one does a multitude of functions.I liked it's ability to take a feed from like two steps from the box directly
The DB2011 is a one of a kind wiring solution for your modern day race car. This board is focused toward the majority of you low power data wiring. It allows you to have a common wiring center for your high tech electronics like your ignition box(MSD), data loggers, EFI, boost controllers, nitrous accessories, inputs and some outputs. Input and output descriptions are below. Power Inputs: Batt+ needs to connect to the positive post on battery with a 10 gauge wire. Batt- needs to connect to a good ground source. An 18 gauge wire will be good as there is no high current pulled through ground. Ign needs to connect to your ignition switch with a 14-16 gauge wire. Inputs: Ret 1-3> are retard inputs that jump to the retards on the ignition section T-brake Button> connects to your main transbrake button. It gets routed to all the spots on the borad that need a transbrake signal. It is also outputted at the OUTPUTS section through a relay and fuse to go out to you transbrake solenoid. Brake Switch> connects to your brake pedal switch. Its outputted at the OUTPUTS to be connected to your brake lights. It also goes to the jumper on the board that allows you to use the brake signal to activate the 3step/burnout limiter at the IGNITION section. This is commonly used for a spool revlimit for turbo cars. LL Button> connects to your line lock button. It gets outputted through a fuse at the OUTPUTS section. It also goes to the jumper on the board that allows you to use the line lock signal to activate the 3step/burnout limiter at the IGNITION section. 12Volt Out> it a fused 12 volt source that can be used to power your transbrake, linelock, and brake buttons or switches. Logger Activation Log, Aux Activation> are inputs that get directed to the LOGGER, EFI, AUX sections to be used for switches. Ignition: Ign> fused switched ignition power to ignition box trig> points trigger output to ignition box. Feed from EFI trigger out.(this is optional only if you want your EFI to trigger your ignition box. Tach> igition tachometer output. This gets routed to various tach outputs on this board. Shift > ground activated input that turns on the shift relay and applies power to the Shift Output terminal. Switch> ground activated input that turns on the switch relay that applies power the the switch output terminal. 3Step> also know as the burnout rev limit input to the ignition box. T/B> also known as the launch rev limit. Connects to transbrake. This gets its feed from the T-button input from the INPUTS section. Ret 1-3> retard stage inputs feed from the INPUTS section. Outputs: LL> fused Line lock output connected to line lock solenoid. Tach signal> tachometer signal to be used for guage and such. Guage power> fused igntion power to feed guages or accessories. Guage ground> ground for guages or accessories. T-brake> fused main transbrake signal to be connected to transbrake solenoid. Shift> fused main shift signal to be connected to shift solenoid. Switch> fused main switch signal to be connected to auxiliary device. Brake light> to brake lights Logger: ign> fused ignition power grd> ground activation> input feed from Logger activation from INPUTS section. Tach> tach signal T-brake> transbrake/launch signal Shift> shift signal switch> switch signal EFI: ign> fused ignition power. Grd> ground tach trigger> tach signal from ignition trigger out> ignition trigger from EFI to Ignition box. Log> signal for EFI datalogger feed from INPUTS section. T-brake> transbrake/launch signal. AUX:used for things like boost controllers, nitrous, ect.. Ign> fused ignition power. Grd> ground T-brake> transbrake/launch signal. Activation> signal feed from aux activation in the INPUTS section. The 3 jumper terminals in the Inputs section below fuses: LL> jump this terminal to the 3-step terminal if you want the 3-step rev limter to activate off the linelock. (commonly used for burnout limiter). Brake> jump this terminal to the 3-step terminal if you want the 3-step rev limter to activate off the brake signal. (commonly used for pre spool on turbo cars).
home of the Sox and Martin Hemi Duster
[Re: Bill_G]
#1195584
03/13/12 11:58 PM
03/13/12 11:58 PM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
My panel was built from Brian Black from Race Wire Solutions. It was totally easy to deal with, I just told him what I wanted and he built it. Its very simple and straight forward to wire. I wired my whole car in a few nights after work. I consider it a plug and play design. Sure, I could have probably built it but I don’t have the time nor did I want too. Good luck……………….
