2001 Concorde P0442 code. Chrysler techs? #1195523
03/12/12 02:58 AM
03/12/12 02:58 AM
Bennett, Colorado
Charger69RT8 Offline OP
Bennett, Colorado
Engine light came on. Only two codes showing. P1684 - Replaced battery a day or two before the engine light coming on. Wifes car, who told me of the light.
From what I have found the P0442 is an EVAP leak. Possibly the gas cap. Checked & it is tight. Will this code set the engine light? Car has 166,XXX miles. Anyone know the most comon issue that causes the P0042 code or is the engine light unrelated? I think maybe I knocked something loose on the EVAP system changing out the battery, but that is just a WAG. Several hoses down around the bottom of the air box which I unbolted at the frame to gain a little wiggle room for my hands. Any clues on a best place to start looking are greatly appreciated?
The car seems to be running fine.
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: Charger69RT8] #1195524
03/12/12 11:42 AM
03/12/12 11:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I had the gross evap leak on my 04 jeep , it also pointed to the gas cap , which is wasn't , also it about the seal in the cap as much as it is about being tight. What it turned out to be was the hoses to the canister , for lack of a better term , that is mounted back near the gas tank. If that is in the area you were working in around the battery that would be the first place to look.
The way the dealer finds the leaks is with a smoke machine , I don't know what that is though.
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: JohnRR] #1195525
03/12/12 09:19 PM
03/12/12 09:19 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
FWIW I got the EVAP code on my Durango. Turns out I left the gas cap at the gas station and it triggered the code. Replaced the cap and the code went away on its own. Try another gas cap if you have a spare or you could probably even get a free one in the lost and found at the gas station.
Common sense is a flower that does not grow in everybody's garden
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: Ron_M] #1195526
03/12/12 09:51 PM
03/12/12 09:51 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Look for a split EVAP hose. They are notorious for this. The bad thing about your car is that you might not be able to see it due to the canister being mounted to side of the fuel tank. The tank may have to be lowered to find it. As mentioned before you may have to take it in and use a smoke machine to find it. Check the hose from the intake to the purge solenoid and the purge solenoid to the fuel tank first. they are the easiest because they are under the hood. Otherwise you have to look by the tank.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: 71yelladustr] #1195527
03/13/12 03:24 AM
03/13/12 03:24 AM
Bennett, Colorado
Bennett, Colorado
Thanks for the replys. That gives me just what I was looking for. Some tips on where to start. It will likely be the weekend befroe I get a chance to to work on it. I'll post back with what I find.
2012 Challenger SRT
69 Charger R/T
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: Charger69RT8] #1195528
03/13/12 04:44 AM
03/13/12 04:44 AM
Unfortunately back in New York
N
Nukechargerboy Offline
N
That code pops up from time to time on my intrepid. I just drive it, the code vanishes eventually. I did replace the cap the first time it happened.
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: Nukechargerboy] #1195529
03/13/12 08:25 AM
03/13/12 08:25 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Ditto
On my 'Trep this code comes and goes
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2001 Concorde P0442 code. Chrysler techs? [Re: 70Coronet500Vert] #1195530
03/14/12 12:58 AM
03/14/12 12:58 AM
Bennett, Colorado
Bennett, Colorado
Nobody has answered specifically on the engine light. Have you all / some got that along with the code?
2012 Challenger SRT
69 Charger R/T
