6.1hemi power steering pump and Power rack #119542
09/12/08 11:25 AM
09/12/08 11:25 AM
Portland,OR
rjsjea Offline OP
rjsjea  Offline OP
Portland,OR
Mocking up a 6.1 w/ an AlterKtion Front and Power rack n pinion. Heard conflicting information on the factory 6.1 pump not gonna work with the AGR power rack. Too much pressue
Some say use an LSx pump and some say it will work fine w/ the factory 6.1pump. Any help is appreciated.
Re: 6.1hemi power steering pump and Power rack [Re: rjsjea] #119543
09/12/08 07:51 PM
09/12/08 07:51 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
I am doing the exact same swap. Check RMS website. I thought Bill told me it would work with the factory pump. Also, Bouchillon sells the adapter for the lines to fit the factory pump.
Let us know if you hear differently.
Re: 6.1hemi power steering pump and Power rack [Re: hemibeep] #119544
09/12/08 08:06 PM
09/12/08 08:06 PM
Portland,OR
rjsjea Offline OP
rjsjea  Offline OP
Portland,OR
I have the Bouchillon adapter and Bill said he is pretty sure it will work, but he has not personally done it
Two others said I will need an LSx pump. These guys have done the swap also....
I am just gonna plumb it with the stock pump and worry about it when it pukes steering fluid all over I guess
Re: 6.1hemi power steering pump and Power rack [Re: rjsjea] #119545
09/13/08 06:16 AM
09/13/08 06:16 AM
808CUDA Offline
808CUDA  Offline
The factory 6.1 pump will be fine.
Street & Perf makes the same misinformed statement about "too much" pressure.
I am using a 1450psi pump on an "ole" recirculating ball box (from Firm Feel stage 2) and no problems/leaks. Street & Perf would have you bring the pressure down to 950 psi which doesn't cut it on this box.
Re: 6.1hemi power steering pump and Power rack [Re: 808CUDA] #119546
09/13/08 11:10 AM
09/13/08 11:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I agree with 808. haven't had any problems running the higher pressures.
Just be careful the higher pressure doesn't create too much heat in the fluid. It wouldn't hurt to run some extra line on the pressure side and/or install a cooler on the pressure side instead of the return. The higher pressure will operate other systems just fine.
Rich H.
Esse Quam Videri
Re: 6.1hemi power steering pump and Power rack [Re: ZIPPY] #119547
09/13/08 11:42 AM
09/13/08 11:42 AM
Portland,OR
rjsjea Offline OP
rjsjea  Offline OP
Portland,OR
thanks...
I am plumbing an external reservoir for cooling. I think it should be ok...
