Page 3 of 4 1 2 3 4
Re: Small block timing chain tensioner- safe to use or not? [Re: 70AARcuda] #1195417
03/12/12 11:05 PM
03/12/12 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Small block timing chain tensioner- safe to use or not? [Re: MR_P_BODY] #1195418
03/12/12 11:45 PM
03/12/12 11:45 PM
K
KOS Offline
KOS  Offline
K
Ryan put one in my build and it broke after 1season.the band(tensioner)broke in two hardly any wear on the nylon i noticed it when i did an oil change a piece of it came out with the oil.when i fixed it i didnt put one back in
Re: Small block timing chain tensioner- safe to use or not? [Re: 5spdcuda] #1195419
03/13/12 12:11 AM
03/13/12 12:11 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
This is clearly one of those "builders choice" items. I've built them both ways and can't really tell any difference in how they ran. Two things worth considering. One: these tensioners were intended to be used with stock type link chains which have a much smoother back than the double rollers typically used in performance builds. 2nd. If you do decide to use one it may not be a bad idea to drill the 4th. bolt hole in the tensioner [ use a standard cam retainer for a template ] and use a bolt with an 1/8 in. hole drilled through the center in the lower left [ looking at it from the front ] bolt hole. This bolt goes through the front of the block and sits in a pocket in the cam valley that collects oil. This would allow oil to drip directly onto the chain and possibly improve wear.
that is some really good advice
If I go the tensioner route I'll be sure to do this...thanks!
Re: Small block timing chain tensioner- safe to use or not? [Re: KOS] #1195420
03/13/12 12:11 AM
03/13/12 12:11 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
that definitely doesn't sound too good
Re: Small block timing chain tensioner- safe to use or not? [Re: 471Magnum] #1195421
03/13/12 12:12 AM
03/13/12 12:12 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Here's the wear on mine after a couple thousand miles...
For all the guys who have experience with these tensioners, does this wear look normal??
Re: Small block timing chain tensioner- safe to use or not? [Re: 471Magnum] #1195422
03/13/12 12:29 AM
03/13/12 12:29 AM
AndyF Offline
AndyF  Offline
We decided not to use one in the 427 SB that was built for Tim's Valiant. The last tensioner got chewed up in just a few laps at the track so we ditched it.
Re: Small block timing chain tensioner- safe to use or not? [Re: AndyF] #1195423
03/13/12 10:18 AM
03/13/12 10:18 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Do you suppose that these are getting chewed up because they were orginally designed for a linkbelt chain?
Re: Small block timing chain tensioner- safe to use or not? [Re: AndyF] #1195424
03/13/12 12:08 PM
03/13/12 12:08 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
so Andy, what is pictured then should not be happening?
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195425
03/13/12 12:24 PM
03/13/12 12:24 PM
dogdays Offline
dogdays  Offline
That Mahle part is not for a smallblock Mopar. Kinda looks like it comes out of a mercedes engine.
Go on Rock Auto look at the timing components for a 3.9 V6, there it is.
You disbelievers are within your rights, but when I overhauled my Mercedes 6 which sees 6500 rpm on occasion and has a timing chain about five feet long, I found two of the chain tensioners. One was actually just a guide around a corner, the other "banana rail" was hydraulically loaded against the chain and I could have reused it, it was still in decent shape. And I found no trace of any plastic on the oil pump intake screen.
R.
Re: Small block timing chain tensioner- safe to use or not? [Re: TrWaters] #1195426
03/13/12 12:39 PM
03/13/12 12:39 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Funny you say this because on summit racing the description for the cloyes tensioner says "for use with silent type chains only"....not too sure what that means, but maybe it is referring to that?
Re: Small block timing chain tensioner- safe to use or not? [Re: TrWaters] #1195427
03/13/12 12:43 PM
03/13/12 12:43 PM
AndyF Offline
AndyF  Offline
Yes, that is my guess. The tensioners seem to last just fine when mated up to a timing chain with a smooth backside. But ours got chewed up quickly with a double roller type of chain.
Re: Small block timing chain tensioner- safe to use or not? [Re: AndyF] #1195428
03/13/12 03:29 PM
03/13/12 03:29 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I'd like to see if anyone has seen any wear beyond what Andy and I have posted pics showing.
Like I stated previously, I'm pretty sure the wear stops once the rollers start spreading the load on the pad.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Small block timing chain tensioner- safe to use or not? [Re: 471Magnum] #1195429
03/13/12 07:00 PM
03/13/12 07:00 PM
dogdays Offline
dogdays  Offline
The abovementioned Mercedes timing chain is double roller and there were grooves that didn't look as ragged as the pictures. After around 90K miles everything was quite smooth and it sure looked like the wear had stopped or slowed way down. As I had already bought the new banana rail I installed it, but wouldn't have had to. There was still quite a thickness of plastic under the grooves.
One other thing, wear probably slows down when the chain has worn in a little and there isn't quite so much pressure on the tensioner. But I'm sure the "silent chain" would wear a lot less on the plastic.
R.
Re: Small block timing chain tensioner- safe to use or not? [Re: dogdays] #1195430
03/13/12 07:09 PM
03/13/12 07:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
The silent chain has alot more surface area that
rides on the plastic so its much slower on wear...
even in the early days on it... the double roller
slows right up on wear as soon as the rollers start
to ride on the plastic(more surface area)
Re: Small block timing chain tensioner- safe to use or not? [Re: MR_P_BODY] #1195431
03/13/12 07:52 PM
03/13/12 07:52 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Small blocks don't seem to get a lot of oil up front so wear/stretch is more heat/fatigue related and of course valvetrain spring tension factors in.
I don't run tensioners on them but I am real particular on the chain's I do run on Smallblocks because the slack will vary between sets.
I remember some well-respected Old timers used to centerline them +2-3 just to "get 'em right' at high RPMs; like they were 'factoring in' the stretch Retarding them. I also knew guys that would swear by the old link chains but with steel gears claiming the 'silent chains' had less friction
WIZE
In Car:
Re: Small block timing chain tensioner- safe to use or not? [Re: mshred] #1195432
03/13/12 11:11 PM
03/13/12 11:11 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I just corrected my original post. It should have said upper left bolt,not lower. Sorry, getting old.
Re: Small block timing chain tensioner- safe to use or not? [Re: 5spdcuda] #1195433
03/14/12 12:44 AM
03/14/12 12:44 AM
Az
Crizila Offline
Crizila  Offline
Az
Think most figured that out, but thanks.
Fastest 300
Re: Small block timing chain tensioner- safe to use or not? [Re: MR_P_BODY] #1195434
03/14/12 12:52 AM
03/14/12 12:52 AM
Az
Crizila Offline
Crizila  Offline
Az
R.
Mine looked like the pic above after about 100+ runs ( double roller chain ). Once the grooves are cut in and the rollers start to ride on the plastic the wear stops. I will be pulling my NA motor down in a few months and I will decide after looking at the tensioner (with close to 200 runs on it ) if I will be putting one on my next motor.
Fastest 300
Re: Small block timing chain tensioner- safe to use or not? [Re: Crizila] #1195435
03/15/12 07:32 AM
03/15/12 07:32 AM
Guitar Jones Offline
The LA engine was fine without a tensioner for over 30 years. MaMopar added it as a bandaid on the odd fire roller motor 3.9 for a noise and now it's supposed to be a performance piece? Not hardly. As others pointed out it was designed to be used with a silent link chain anyway and not a roller. It's unnecassary in my opinion.
Re: Small block timing chain tensioner- safe to use or not? [Re: Guitar Jones] #1195436
03/15/12 01:06 PM
03/15/12 01:06 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I guess a guy could machine the tension blocks for a roller chain.
Page 3 of 4 1 2 3 4
