Small block timing chain tensioner- safe to use or not?
#1195377
03/12/12 01:44 AM
03/12/12 01:44 AM
Posts: 3,422 Toronto
mshred
Toronto
Hey guys, Putting my LA 360 back together and im reusing my old timing set. Its a Cloyes true street roller, and even when it was brand new the chain felt kinda sloppy...I re installed it the other day and im not sure im too happy with how it feels and was thinking of using a tensioner on the chain to take up the slack. My worry is the reliability of these pieces (All I know of is the MP one...are there other brands?). I have read of some using them with great success and others saying that they get eaten up. My car sees upward of 3000 miles on the street every year, and lots of very hard driving on and off the track. Rpms will be under 7k. Not sure if any of this has a bearing on whether the tensioner will work ok in my application. Is there any special install guidelines that anyone recommends when using them? special lube? effects on cam degreeing (already degreed the cam but can be done again if I should). Just looking for some opinions on whether these are a good piece or if I should stay away from them and any tricks or things to watch out for when running them Thanks Matthew
Re: Small block timing chain tensioner- safe to use or not?
[Re: mshred]
#1195378
03/12/12 07:00 AM
03/12/12 07:00 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I managed to get one when we were doing these all the time in the dealership. Seems like a good idea---but I can tell what happened to mine. I was mocking up my 360 and put the chain on by itself. Motor turned over effortlessly (just crank, cam, and chain). I then put the tensioner on and the struggled to turn the enging over with a 3/8 ratchet. I pulled it right off in the trash it went. I just couldn't see putting the added drag---a significant amount--- on the engine. Not worth it in my opinion at all just for that reason alone, let alone any wear issues tha my occur on the wear pads.
As long as you buy a good double roller, thats about the best your going to do short of going to the Milidon gear drive. Which I eventully did and had rock steady timing.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1195379
03/12/12 10:00 AM
03/12/12 10:00 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
My motor from Ryan J has one. I beleive he likes them on all his chains.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1195380
03/12/12 10:02 AM
03/12/12 10:02 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
they work great and my 416 was no harder to turn over with it or with out.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Moparnut426]
#1195386
03/12/12 12:49 PM
03/12/12 12:49 PM
Triple Threat
Renton Washington
I asked Ryan this when I was ordering parts for my new bullet. He said to run one, so I am. We'll see how it holds up to all the street driving and passes I put on in a year.
[Re: dogdays]
#1195388
03/12/12 12:57 PM
03/12/12 12:57 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
When you see how much the nylon wears in such a short time, and it's all in the oil/oil pan you'll never run one again!! Gimmick if you ask me. Buy a good timing set and be done.
Brian Hafliger
[Re: Brian Hafliger]
#1195389
03/12/12 01:30 PM
03/12/12 01:30 PM
Posts: 339 western PA
stevet340
western PA
I would never run one, just buy a good QUALITY chain and gear set. It may be a bit pricey, but a lot of times you really do get what you pay for and being cheap is not the way to go in the long run! I have never been dissapointed buying quality parts over buying cheap parts...
#1195390
03/12/12 01:38 PM
03/12/12 01:38 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree,,,,never liked them, never will...dont think you need one. No way of telling from a computer screen what your dealing with as far as "loose", but it could be the align hone if there was one, a cheaper timing set with a chain that stretched easily, sprockets wearing faster than they should, or lack of oil supply to the timing set.
RIP Monte Smith
[Re: Moparnut426]
#1195392
03/12/12 02:19 PM
03/12/12 02:19 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I just pulled my motor apart due to a wiped cam after a few thousand miles. When I built it, I installed a Cloyes tensioner.
There is visible wear on the pads. Wish I had pictures handy, but the chain “bars” have worn grooves in the pad. Looks like it wore in until the rollers started hitting the pad, and then stopped. With the effective bearing surface increased, the wear will probably stop.
Before I re-assemble though, I’d like to hear some other tensioner wear stories.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1195393
03/12/12 02:23 PM
03/12/12 02:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats the normal wear pattern... as soon as it gets more surface area it slows right down on wear
#1195395
03/12/12 02:42 PM
03/12/12 02:42 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I agree here, but its a total crap shoot, and personal preferance. Will one make or break an engine, doubt it, will I run one, NO, do I care if someone else runs one, NO. All part of the Hot rod game. Some people LOVE header wrap, some HATE it, same thing here. Kasey
