Which aluminum intakes will fit properly #1195373
03/12/12 12:48 AM
03/12/12 12:48 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Which aluminum intakes will allow the proper fitment with the ramcharger hood and air box on my '69 R/T hood? The engine is a 440 with single 4bbl street engine. I know that some intakes are too tall, but I haven't yet researched all that are on the market. What do you guys recommend?
I have a factory unit, but I just want to use a lighter weight one.
Thanks,
Jerry
Re: Which aluminum intakes will fit properly [Re: 3_RTs] #1195374
03/12/12 12:53 AM
03/12/12 12:53 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Find a used edelbrock CH4B. Pretty decent intake for a mild 440 and almost as short as stock.
Re: Which aluminum intakes will fit properly [Re: DaytonaTurbo] #1195375
03/12/12 12:23 PM
03/12/12 12:23 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thank you, Daytona.
Re: Which aluminum intakes will fit properly [Re: 3_RTs] #1195376
03/12/12 12:29 PM
03/12/12 12:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have a '69 r/t with the ramcharger fresh air stuff. i don't think anything will fit with a stock air cleaner assembly except the factory iron or mopar performance alum dual plane.
