70 swinger part id #1195343
03/11/12 11:56 PM
03/11/12 11:56 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Looking for a picture of the hood scoop bezel screws.I have none and need to know what
I am looking for.Thanks.
Re: 70 swinger part id [Re: crowbait] #1195344
03/12/12 07:38 AM
03/12/12 07:38 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Are you looking for factory looking install or daily driver? Most of the bosses were broken on mine and I just made a small wooden template and affixed it to the proximity of the originals. After it was dried I opened up a slightly larger than 1/4" hole. Drilled two perpendicular holes on the recessed nut then filled the hole on the boss with some epoxy, dropped the recessed nut in the hole and tightened a stud into the nut.
At higher speeds those factory deals would come apart so I beefed it up. Over 120mph and my whole hood was shaking those scoops never vibrated loose...
Not really an answer to the question but make sure those bosses are intact and can take the stress.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 70 swinger part id [Re: Pyper70] #1195345
03/13/12 09:11 AM
03/13/12 09:11 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
This is for the chrome trim on the front edge of the scoops.Should be the same as a super bee fresh air hood.
Re: 70 swinger part id [Re: crowbait] #1195346
03/13/12 09:53 AM
03/13/12 09:53 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It's been quite some time since I've had any of them in my hand.
so don't shoot the messenger
But, I think they are either a #8 or a #10 x 3/4" countersunk oval headed screw - chrome
Re: 70 swinger part id [Re: gtx6970] #1195347
04/01/12 09:45 AM
04/01/12 09:45 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Thanks for the help guys.
