Re: which is more consistent for bracket raceing
[Re: slowpoke68]
#1195329
03/11/12 11:47 PM
03/11/12 11:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Any engine can run consistent if its tuned right... to make a car consistent I would make it LIGHT which is easier on parts
[Re: tubtar]
#1195330
03/11/12 11:48 PM
03/11/12 11:48 PM
Posts: 2,517 PA
moparacer
PA
Either way... Make it big inch.
Small engines seem to be more susceptible to changes in the air.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: slowpoke68]
#1195331
03/11/12 11:48 PM
03/11/12 11:48 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I'd build a alum. headed low deck big block like a 451. or steal all the parts you can from "whitedart" and go smallblock.
"Just a Bracket car dressed up like a streetcar"
[Re: HotRodDave]
#1195333
03/12/12 01:37 AM
03/12/12 01:37 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You want to run low tens? At what weight? Lets say you budget to get down to 3200 lbs. You will need 625/650 hp on the dyno to run 10.0s consistently in average midwest air. My choice would be a 512 bb based on a 400 block. A set of massaged small port heads, run E85, and a glide. A 590 or similar flat tappet cam ought to do the trick. A set of 14/32 slicks on 14 inch rims and you should be absolutely deadly once dialed in. About a 5000 converter (no less), shift at 6000 rpm and it will last a LONG time. You probably will want to run a 4.10 gear also. I had a 475 with 440-c heads, a juice cam with .540 lift and a small 750 methanol carb and went 10 teens at 3180 lbs as an example of what can be done with out breaking the bank.
[Re: gregsdart]
#1195334
03/12/12 03:13 AM
03/12/12 03:13 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
S'what I'm talkin about. Losing weight makes a ton of sense too , but a big motor that isn't maxed out will be the most cost effective and reliable route to my way of thinking.
[Re: gregsdart]
#1195335
03/12/12 11:59 AM
03/12/12 11:59 AM
Posts: 3,453 Dandridge TN
Dabee
Dandridge TN
Hay you just described my combo with some minor differences. I have an RB block, 4.15 stroke, 496 ci, OTB Eddy heads, 5.60 lift, PG, 5400 stall converter, 4.67 gears and 14-31-15 slicks on a 12 in rim. The car weighs 2900 lbs and it is deadly consistent. It runs 6.56 1/8 mile in 2000 to 3000ft DA.
[Re: Dabee]
#1195336
03/12/12 12:11 PM
03/12/12 12:11 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
I agree that with work any combo can be dealdy consistent. Just takes hard work and persaverance.
To the posters question in my mind a BB would be the best choice. The reason being it will be a much more mild engine build. I also think you can build a 650ish HP BB for less money than a SB of similar power levels.
But either can be made consistent. Being a consistent money winning bracket racer is about the total package not just the power plant. Every part of the car needs to be built, tweaked with an eye toward repeatability.
[Re: Al_Alguire]
#1195339
03/14/12 01:52 PM
03/14/12 01:52 PM
Posts: 4,209 New York
polyspheric
New York
X2 - less violent launch due to taller 1st gear ratio, plus half as many shifts.
Boffin Emeritus
[Re: polyspheric]
#1195340
03/14/12 02:11 PM
03/14/12 02:11 PM
Posts: 2,517 PA
moparacer
PA
Yep if you wanna look cool and do a big wheelie put a bunch of gear in it and a 727/904.
If you want to go rounds bracket racing take some gear out, put a glide in it and run a looooose converter...
Probably 2-3 tenths slower that way but you will turn more win lights on. Especially if you are running in the 9s on questionable tracks.
[Re: moparacer]
#1195341
03/14/12 02:48 PM
03/14/12 02:48 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Big tires=no traction issues Solid, simple chassis=consistant hook Light weight=less strain and wear Build toward more torque, less HP=less RPM, less wear and maintainence solid, strong trans and converter=same performance Gas is cheaper, but alky is more forgiving of A/F ratios and doesn't require as big a cooling system. There are lots of 15-18 second cars that are deadly, but you say 10s. Either a BB a-body with a good chassis and suspension and a solid big inch low RPM combo 2800-3200# or a tube car with an alky small block that weighs under 2400#. I've seen SB A bodys run 10s all day long. They require more money up front and more parts/maintenance.
[Re: RodStRace]
#1195342
03/14/12 11:13 PM
03/14/12 11:13 PM
gregsdart
I have found that the torqueflite isn't a consistency problem as long as you have good weight distribution and a proper setup, plus the recommended big tires. Rear gears should be a little on the tall side for two reasons. Cut launch torque some, and for consistency on the shifts. If I can make a three speed deadly at 8.90s, I can't see why it can't be done in the tens. The one area you might have a problem with is on a pro tree. I have a Griner brake, one of the best. I am on the bubble as far as car reaction time goes. So if you plan on 9.90 (.400 light)or quicker pro tree racing in the future then the glide will be a good choice.
