exh. manifold stud sealant #1195228
03/11/12 07:42 PM
03/11/12 07:42 PM
Southern CA
Colin Frolick Offline OP
Southern CA
the book for my 2001 ram says to use sealant on the center exhaust bolts on a 5.2L
these go into the water jacket I presume
do you all routinely do this and what kind of sealer do you recommend?
i just put on pacesetter headers and repaired the intake plenum
it is sad how much DIRT the factory air box let in to this motor... it seals very poorly around the throttle body.
i also added an aFe intake made in corona, ca... a very nice piece.
Cheers!
Re: exh. manifold stud sealant [Re: Colin Frolick] #1195229
03/12/12 01:13 AM
03/12/12 01:13 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I use permatex high temperature thread sealant.
