727 problems HELP!!! #1195098
03/11/12 12:33 PM
03/11/12 12:33 PM
middle tennessee
71RTC Offline OP
71RTC  Offline OP
middle tennessee
I HAVE A 727 THAT HAS BEEN GONE THRU SEVERAL TIMES AND THEY SAY NOTHINGS WRONG BUT NO REVERSE? PULLS FINE IN OTHER GEARS. ANY IDEAS??? THANKS
Re: 727 problems HELP!!! [Re: 71RTC] #1195099
03/11/12 12:51 PM
03/11/12 12:51 PM
NC
440Jim Offline
440Jim  Offline
NC
The rear band is applied in reverse and in "1" or "L" with a factory valve body. But not in "D". So first gear will work even if the rear band doesn't engage, but reverse won't. With the shifter in "R", the front clutch is engaged, the rear clutch is disengaged, the front band is disengaged and the rear band is engaged.
Air test the rear servo for excessive leakage, and look for rear band to servo linkage issues. You can pull on the rear servo lever by hand and check for proper movement, no binding, etc.
Also check the shifter, shifter linkage, etc.
Last, it could be some valve body issue? Swapping a known good one for a check.
Re: 727 problems HELP!!! [Re: 71RTC] #1195100
03/11/12 02:05 PM
03/11/12 02:05 PM
Check the rear servo, if that is not it probally the valve body malfunctions
Re: 727 problems HELP!!! [Re: 71RTC] #1195101
03/11/12 03:30 PM
03/11/12 03:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A little more info on the trans would be helpful.
In some cases, when the valve body is modified, the large check ball is mistakenly omitted...this will cause no Reverse with all forward gears OK.
Re: 727 problems HELP!!! [Re: Cab_Burge] #1195102
03/11/12 03:33 PM
03/11/12 03:33 PM
middle tennessee
71RTC Offline OP
71RTC  Offline OP
middle tennessee
ok thanks for the input. I just installed a brand new valve body yesterday(3rd new valve body to go in it). I am not really a transmission guy can this test be done with the transmission still in the car or do I have to remove it?
Re: 727 problems HELP!!! [Re: 71RTC] #1195103
03/11/12 03:39 PM
03/11/12 03:39 PM
middle tennessee
71RTC Offline OP
71RTC  Offline OP
middle tennessee
the valve body i put in is a cheetah manuel shift, the other two were from a&a pro brake valve bodies
Re: 727 problems HELP!!! [Re: 71RTC] #1195104
03/11/12 03:45 PM
03/11/12 03:45 PM
middle tennessee
71RTC Offline OP
71RTC  Offline OP
middle tennessee
also tried to unhook the linkage from the shifter and put it in reverse but no luck, this transmission was built by a mopar transmission guy but im tired of pulling it out and losing money and time its been gone thru several times
Re: 727 problems HELP!!! [Re: 71RTC] #1195105
03/11/12 03:56 PM
03/11/12 03:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Did this trans ever work? Air test the low/reverse servo, using the case port posted. Also, if the accumulator piston has beeb blocked with a rod, make sure the length doesn't prevent the valve body from seating fully against the case. Beyond this, someone else needs to look at it. Sorry.
Re: 727 problems HELP!!! [Re: 71RTC] #1195106
03/11/12 04:15 PM
03/11/12 04:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u have to hold the transbrake button in to backup with a probrake vb. seeya.
Re: 727 problems HELP!!! [Re: Leigh] #1195107
03/11/12 08:05 PM
03/11/12 08:05 PM
NC
440Jim Offline
440Jim  Offline
NC
Good thing to check. It doesn't take much, and simply removing the blocker rod and trying it will tell you. (valve body R&R required to get at it).
To air test the rear servo,
- remove the valve body
- using 30-60 psi of shop air and a rubber tipped nozzle, pressurized the port shown.
- some fluid will leak, but the servo should actuate and engage the rear band (visual movement).
Re: 727 problems HELP!!! [Re: 440Jim] #1195108
03/12/12 11:41 PM
03/12/12 11:41 PM
middle tennessee
71RTC Offline OP
71RTC  Offline OP
middle tennessee
thanks for the input i will give it a try!!
Re: 727 problems HELP!!! [Re: rickraw] #1195109
03/13/12 12:23 AM
03/13/12 12:23 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
My first learning experience with a transbrake, lol.
8.30's @3400 lbs
